http://www.sky-manufacturing.com/accessories.htmKWP, they're half way down the page
yes I have screwed up a set of wheels. they don't work unless the bead ring is really small. If you have to put the tire on from the rear of the wheel then you can't bead lock em unless you wanna have the lock on the inside. if you can mount the tire from the front then it can be bead locked.HTHWayne
I have read somewhere that it is doable, but you need to use a different type of inner ring... Oh well.. Not really needing them except they are bada$$
Wouldn't that be a rough hit if you had 1 or 2 psi and you came off a rock, then it would compress the 1-2psi and then boom! hit the 48psi rock hard inner tube..
That's valid, but unless you got really stiff sidewalls with conventional beadlocks youll still be feeling the rim smack down wouldnt you?
Yes, however there would be another 2 or 3 inches of compression required to bottom out with conventional beadlocks, or whatever thickness the Saturn ring is when inflated.The Saturn system does seem like a good idea and its cool to see people thinking out side of the bun.
I am trying to figure out how that is going to work if you still have the outer lip still on the wheel.Does the tire get clamped between the ring you welded on and another ring that bolts to it. Assuming the tire does not go all the way back on the wheel.
AHH, Does the bolt on ring have a shoulder for the bead?
Started by E YOTA Parts Wanted
Started by Jack8542 Engine
Started by abnormaltoy Project Research and Build-Ups
Started by ToYocRawleR For Trade or Barter!
Started by a1gemmel Project Research and Build-Ups
