Author Topic: SAS on a 92 Toy  (Read 1467 times)
CJTownsend
  • Male Posts: 41
  • Member since Jan '06
  • Brand New 92
SAS on a 92 Toy
« on: Jan 09, 2006, 12:20:36 PM »
I have a 92 toy that im wanting to put a solid axle under. I have an axle out of an 85 pickup. I do drive this on road alot more than off road so i would like to use a sway bar with quick disconnects and a torque rod. Im new at this so i need any as many hints, tips and tricks.
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: SAS on a 92 Toy
« Reply #1 on: Jan 09, 2006, 08:05:10 PM »
I don't think this would be terribly hard to do.  Maybe zip-tie your sway bar up out of the way when you hack off the ifs crap then see how it lines up when you have the new axle in place and take any measurements to see how long of links you need.  After that you should be able to source out quick disconnects to the proper length, maybe nwor or?
CJTownsend [OP]
  • Male Posts: 41
  • Brand New 92
Re: SAS on a 92 Toy
« Reply #2 on: Jan 11, 2006, 01:13:44 PM »
Has anyone used a NWOR torque rod adapter. Also im in the process of finding a small block ford motor(5.0 HO FI Mustang) and trying to figure out what size gears i need to run with 36's?
scyota
  • Male Posts: 427
  • Member since Aug '05
Re: SAS on a 92 Toy
« Reply #3 on: Jan 11, 2006, 03:58:03 PM »
for 36's you will need to run 5.29s
1993 4Runner SAS - SOLD
'01.5 Audi S4 2.7TT Stage 3
CJTownsend [OP]
  • Male Posts: 41
  • Brand New 92
Re: SAS on a 92 Toy
« Reply #4 on: Jan 12, 2006, 09:56:57 AM »
Has anyone used the North West Off Road torque rod adapter with a SAS with a 5 or 6 inch lift? I would think 5:29's are to low because thats what North West Off Road recommends with the stock 4 cylinder. I'm thinking like 4:37's or 4:56's with the 5.0?
« Last Edit: Jan 12, 2006, 08:44:35 PM by CJTownsend »
KWP
  • Male Posts: 878
  • Member since Jul '04
  • Ghost Hunter
    • East Central Oklahoma Paranormal Society
Re: SAS on a 92 Toy
« Reply #5 on: Jan 13, 2006, 04:43:33 PM »
With a 5.0 and 36's you'd be fine with 4.10's
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
CJTownsend [OP]
  • Male Posts: 41
  • Brand New 92
Re: SAS on a 92 Toy
« Reply #6 on: Jan 15, 2006, 07:17:34 AM »
So has anyone used the NWOR torque rod adapter with 6'' SAS? Ive herd that you dont need it if you use a hysteer kit? Is this true? I will be driving this more on road than off plus i will be putting the 5.0 in it if that makes a difference.
« Last Edit: Jan 16, 2006, 08:36:07 PM by CJTownsend »
