Hydraulic Winch?
Started by 1Bad4Runner, January 02, 2006, 04:26:13 AM
1Bad4Runner
I found a Ramsey 8000 pound winch for $500 and it is hydraulic, is this worth it? if it is, has anyone ever hooked one up before?
lowgeared
I'd save your money.  #1 Only works when engine is running.  Usually after a roll over, this isn't the case.  #2 They are sssssssssslllllllllloooooooooooowwwwwwwww.  #3 They are sssssssssllllllllllllloooooooooowwwwwwwwwww.  Get an electric winch, run dual Optimas and you are in there like swim wear.
1Bad4Runner
Thanks lowgeared... then I will have to go with a Warn or something.
Matt_BC
Quote from: 1Bad4Runner on January 02, 2006, 01:10:43 PM
There are certainly pros and cons for either electric or hydraulic ... biggest selling point is the fact that the toyota power steering pump isnt up to powering a winch, so i was told by a milemarker rep...
Unless you are up for upgrading the pump you have the answer right there:
get an electric winch
Matt
1Bad4Runner
if I were to do it, I would get a 1 ton power steering pump off of a Cummins or something... I would assume that would move it.
But I will most likely see if I can find a deal on a nice Warn or something.
