mixing drivelines
Started by Skinny_Pedal, December 17, 2005, 11:59:09 AM
Skinny_Pedal
well nick(to the floor) came up with a good idea. im in need of a rear driveline for my 85. he has one for an 83. could i take out the u-joints and the end flanges, and use the flanges from my 85 on the 83 driveline. then go have it balanced?
Im an OG
IronClad
yes. and unless you are modifying the tube  there is no need to have it ballanced
Annihilation  Fabrication
Do you need a Hammer?
why not just use the 83 driveline :dunno:
IronClad
the bigger bolts are much stronger :D  plus the flanges have more angle
BUDDERS
Are we talking regular cab here guys?
To The Floor
Quote from: BUDDERS on December 17, 2005, 11:40:05 PM
yes it is a regular cab, but it's a long bed so it's the same as an ex cab.  we're thinking about just puttin his pinion and tcase dline yokes on the 83 bcuz theyll match up to his pinion and tcase flanges, thats why we wouldnt just use the 83 in its entirety.
Skinny_Pedal
so then i also take it that the u-joints are all the same?
Im an OG
IronClad
yep  a toyota ujoint is a ujoint is a u joint
toybuilt
sounds like it should work if you swap out the end flanges on the driveline
1983 Toyota Turned Chevy
Skinny_Pedal
Im an OG
Quote from: Skinny_Pedal on December 18, 2005, 12:53:24 PM
well hott dam
:rofl2:   glad he thought of that huh skinny :rofl:
i know my front shaft is almost maxed out just sitting there, if it droops it binds
nothin some :eyebrow: modifying :eyebrow:  and a MC07 wont cure
notajeep
Why not just drill out the flanges? :dunno: The only difference is that the 83 has an 8mm hole and the 85 has a 10mm hole... Right??
IronClad
no the bolt pattern is also different. there is a offset to it
ironclad,  i think i have one of those offset flanges,   are all the 85 and up trucks like that ??
so essentially your doing this
toybuilt
I have one of those that I don't need anymore
