Lookin at rear axles
Started by Dooner, December 10, 2005, 07:42:02 PM
Dooner
Hey guys, I want your opinion,
which axle would hold up better under a 327 Cruiser, a GM 10 bolt, 12 bolt, late model Toy V6, or Dana 44? I need a center diff rear end.
thanks, Mike :headscratch:
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
crawlerdan
10 and 12 bolt are prety strong, safe for 35s or so with a v8, a 44 would be a little better, but believe it or not the toyota rear has got my vote as the strongest and by far the most compatable with the rest of the rig :thumbs:
Quote from: Dooner on December 10, 2005, 07:42:02 PM
where are you located??
toy V6  is probably all you need
but maybe a 12bolt or 44 if you have one handy
10bolt would be a waste of your time
IronClad
10bolt rearend are OK but the 12bolt is even better  orrrr.. 10 bolt housing with 12bolt side gears to run 12bolt  shafts  so you can go to 5.56 gears and get a 10bolt front :).. 12bolt rears are great also  ive seen them hold up to 40"+ tall tires  in hardcore extreme bound up situations.
Annihilation  Fabrication
Do you need a Hammer?
Dooner
Im in the Fresno Area, in Clovis.
kyle_22r
i personally believe the 10 and 12 bolt gm rear ends are complete pieces of junk.  pretty sure they're still around from some secret agreement with gear shops to keep them in good business :laugh:
with a V8, 35s, and a heavy rig like a cruiser, i'd be looking at something like a ford 9" or a dana 60 rear end.  both are pretty easy to come by and plenty strong enough.
crawlerdan
ok...i understand that some have grudges with the 10/12 bolts...but let me say this-i personally owned a 12 bolt that i found in a feild-put 5.38s and a spool in, and ran without changing bearings or anything like that. i had it in a truck with 39.5 boggers that i frequently ran at 2 psi- and had triple transfer cases in that truck, so lots andlots of torque going through it, not only did i NEVER have any problems with it, but it held up through 45 or so rubicon trips 50 or so fordyce trips, freeway driving, the little sluice, trees, and my dumbass playing monter truck rally and jumpung the hell out of it.
not to shabby for an axle that is as easy to find as toes-and so cheap to build and maintain its stupid.is it as strong as a 60? no.
but compared to the costs in building both...id take it any day--dan :twocents:
IronClad
hell yea dan!  people that talk smack bout 10/12 bolts are usually misinformed  about them. they usually see the  OMG C CLIP !!!   funny how alot of guns run a semi float ( c clip) 60 rears in their rigs.. i know of one thats under a yota  223:1  and 49" iroks and has not broke. the 44 front.. well...  he broke a moser inner/outer ( ears) but the ctm survived..  but thats a snow rig..  sees rocks in the summer ontop of 44" boggers
KWP
Quote from: IronClad on December 11, 2005, 01:52:11 PM
When I asked aboout running a d44 and 12 bolt under my rig I was told it was a waste of time :dunno: . I personally don't have much experience with these axles, just wanted to go fullwidth and be able to keep my current beadlocks. I would also like to hear more about them because I can get a set for next to nothing from under a 3/4 ton suburban.
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
crawlerdan
i ran a 44 and a 12 bolt in my competiotion buggy, again, with 39.5 boggers, and a 441.1 crawl ratio only problems i had was breaking stub shafts in the 44, until i went to chromos. easy to find parts for, cheap also. unless you got 60s layin around, or have unlimited funds, a 44 will be great in an average wheeler :thumbs:
toybuilt
I'm a Dana fan so of course I'm going to say go with the Dana 44.
1983 Toyota Turned Chevy
kyle_22r
no such thing as a C clip dana 60.
and a dana 44 is no better than a toyota rear end...
crawlerdan
actually, my freing owns a c clip 60, came stock in some fullsize ford and lincoln cars
IronClad
Quote from: kyle_22r on December 11, 2005, 07:34:29 PM
guess you should read up on your axles then..  i know of 5 people  that have one in their toyota..   might go to a junkyard and look around and see what you find ;)
S-10 Stewy
Sorry Kyle .... if you compare apples to apples, the material used in the Toyota's are a different (stronger) material then most others.  Main reason they last so long and work so well for wheeling.  We can thank the Japs for this many years ago when they started building cars.
It's built Chevy tough with Toyota stuff!
IronClad
dont forget that  the cruisers used c clip rearends ;)
