Your heater core would not have that much effect on engine temp, and if it was clogged, youd get NO heat thru it. What kind of stat did you put in it? I've seen brand new ones stick open. What temp was it. Should be 195*. Are you running stock fan clutch or electric fan? Clutch could be locked up, pulling air thru all the time, or if its electric, it could be stuck on, but you'd probably notice the noise. Also, what kind of gauge is on it? Stock, or mechanical gauge?
The thermostat was a cheapy Autozone one.
I have the same problem, but my engine gets to temp, but heat sucks? How do you blow out the system?Thanks
Started by WHITE_TRASH Chit Chat Camp
Started by Skinny_Pedal Chit Chat Camp
Started by vxrich Stolen Rigs and Theft!!
Started by BigMike Chit Chat Camp
Started by 85yotabox General 4WD Discussion
