Total Members Voted: 42
12 around town, 6-12 playing in the snow. 37", 4.37's and a 4 speed.
About 15. 31s, 4.37 gears and L43. This is also runnin a weber 32/36 tuned a little bit, 4 into 1 hedder, open exhaust and a pretty stock hybrid. And lilbuddy, it doesn't so much matter if you're floored or not, what really matters is your rpm, ie: the higher the rpm the more air is being sucked in, hence the more fuel being sucked in. Try bogging your truck a lot around town and see if your mileage picks up or not, worked for me. Not sure how that works on efi rigs though, how much the ecm compensates or ? I get pretty consistent 26mpg in the granny truck.edit: my boggin theory doesn't necessarily transfer to hilly driving though since you're putting a heavier load on your engine, it's more of a flat ground/cruising deal.
actually with a carb there's gonna be more fuel spitting through in a low vacuum situation(foot to the floor) due to the power valve. keeping the secondary closed until you need it really helps with fuel economy
nate, my 4x2, is more 4x4 then most people want to believe.....possibly not here, but in general... you probably wont see too many 4x2s built like mine, if any without some major crazy longtravel suspension or somethign converted to a tcase with a front axkle
