spring hangers question
Started by Gearhead Wiki, November 29, 2005, 04:20:57 PM
Gearhead Wiki
Im trying to remove the springs from the hangers and im having one helluva time.  Im probably not noing something but is there a trick to it?
My automotive wiki project https://www.gearheadwiki.com
Quote from: 82yoda on November 29, 2005, 04:20:57 PM
WD 40 & a big hammer. Sometimes they get rusty stuck.
sdiker
do you mean that you can not get the pin out of the spring ends or the shackle off the springs, they are easily rusted and seized on, try heating the pin/shackle with a torch, it shouldnt take to much heat but the old bushings will probably burn and melt a bit and then the pins should slide out fairly easily, when you put it all back together lube it regularly and it will come apart with ease next time.
04 Ram Hemi 4x4
47 willys
MiniSimp
No matter what way they are stuck there is only one solution that you need:
BFH!
