Jul 20, 2024, 02:17:47 AM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Technical Discussion
Project Research and Build-Ups
(Moderators:
Willy Mammoth
Blingn
Topic:
T/H 350?
Pages: [
1
Go Down
Print
Author
Topic: T/H 350? (Read 2358 times)
BUBBA
The 1K Club
Turtle Points: 16
Member since Mar '05
this sucks
T/H 350?
on:
Nov 26, 2005, 09:53:12 AM »
I'm in the process of swapping in a 350 in my runner.The turbo 350 tranny I have has had the bellhousing broken and welded back together.I don't want to use it like this.I have several 2wd turbo 350's laying around.Are the case's the same.If so I am just gonna swap out internals and be done.
Logged
My budget beater
Gold Turtle Award
Turtle Points: 1128
Member since Oct '04
Re: T/H 350?
Reply #1
on:
Nov 26, 2005, 12:19:15 PM »
From what I've been told yes, the difference is in the tailshaft, but let's wait and see what others say.
Logged
gotrocks
The 2.5K Group
Turtle Points: 107
Member since Dec '04
FLOOR IT!!
Re: T/H 350?
Reply #2
on:
Nov 26, 2005, 01:13:51 PM »
I'm pretty sure the tail shaft is the only difference. When I was looking for a 350 for my swap I look around and eventually have a tranny shop build me one and all I needed to tell them was I needed the short 4wd output shaft. So from what I understand of it is that you just need the shorty 4wd output.
Logged
Owner of DC Custom Fabrication in Cashmere WA
FAMILY TRUCKSTER
http://board.marlincrawler.com/index.php?topic=100576.msg1122729#new
Toyota-Holic build (budget wheeler)
http://board.marlincrawler.com/index.php?topic=49049.0
76 FJ40
My 99 Tacoma being SAS build TACO LIBRE
http://board.marlincrawler.com/index.php?topic=38320.msg463165#msg463165
SN FAB Buggy
http://board.marlincrawler.com/index.php?topic=26696.new#new
Kris
Rock Crawl'n
Turtle Points: 94
Member since Oct '05
Crawling with Marlin
Re: T/H 350?
Reply #3
on:
Nov 26, 2005, 01:42:19 PM »
I had a 700R4 in my Chevy and went to a 350. The 350 was out of a two wheel drive truck. The only difference is the output shat is shorter in a 4 wheel drive application than 2 wheel drive. You can buy a kit that converts it to a short shat for very little money.
Logged
Better to be judged by twelve than carried by six!!
You can grow, You can hide it, You can build it:
BUT WE WILL FIND IT!! K-9
BUBBA
[OP]
The 1K Club
Turtle Points: 16
this sucks
Re: T/H 350?
Reply #4
on:
Nov 26, 2005, 04:21:18 PM »
I know the shaft is shorter.The one I have is a 4wd.The question I was asking is,are the cases the same.Is one stronger than the other.
Logged
My budget beater
Kris
Rock Crawl'n
Turtle Points: 94
Re: T/H 350?
Reply #5
on:
Nov 26, 2005, 06:04:43 PM »
my bad. NO the cases are the same just the shaft is different.
Logged
BUBBA
[OP]
The 1K Club
Turtle Points: 16
this sucks
Re: T/H 350?
Reply #6
on:
Nov 27, 2005, 10:57:54 AM »
thank's Kris
Logged
My budget beater
- Sales Employee -
freds40
The 2K Group
Turtle Points: 293
Member since Dec '02
Re: T/H 350?
Reply #7
on:
Nov 27, 2005, 07:24:45 PM »
There are actually 2 if not 3 different cases. There is the 2wd case and a 4x4 case. The 4x4 case is called a "K" case as it has a letter "K" about 3" tall on the bell housing. The third I'm not positive of but I believe there is an hd case as well. If your guts are good, for $200 you can get a bolt on bellhousing from Jegs or Summit they use for drag cars. You actually cut off your bellhousing and bolt this to the pump comer bolts. It is super stout and saves the need for rebuilding a case.
Logged
"between projects"
hawaii500_1999
Crawler Guru
Turtle Points: -7
Member since Jun '02
Watch this!!!!!
Re: T/H 350?
Reply #8
on:
Nov 27, 2005, 08:41:44 PM »
all of the 350 cases will work, but the 4x4 case is better cause it's thicker.
running an aluminium pan helps with case strength as well.
Logged
1985 4runner on 35 boggers. 22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
BUBBA
[OP]
The 1K Club
Turtle Points: 16
this sucks
Re: T/H 350?
Reply #9
on:
Nov 28, 2005, 09:28:51 AM »
The case I am going to be swapping the guts into is a 2wd,but it has a big H on the bellhousing,does that mean anything.I have heard the hd cases had 6 bolt cast aluminum dust covers rather than the 4 screw stamped sheetmetal one's,I know the 4wd 400's had this,but I don't know about the 350's.
Logged
My budget beater
Pages: [
1
Go Up
Print
(Moderators:
Willy Mammoth
Blingn
Topic:
T/H 350?
