1989 Toyota Xtra-cab 4x4 Pickup. Molalla, Oregon
Started by Spider, November 15, 2005, 08:44:28 PM
Spider
1989 Xtra-cab Toyota 4x4 pickup.
3.0L V6
5 speed manual (auto-manual conversion)
Blue outside / Blue inside
~209,000 miles (~25,000 on rebuild)
31x10.50x15 AT tires
Power steering
Tilt steering
Air conditioning (blows cold)
Sliding rear window
Matching canopy
Toyota bedliner
Tow package
Aisin Hubs
A.D.D switch (turn it on and off inside the cab)
Fog Lights
K&N
Clear running lights
Altezza Tail lights
Chrome Bumpers
Chrome nerfbars
White face gauge kit (changes a couple different shades)
Clifford Alarm
Factory jack hardware
Electric door locks upon arm/disarm
New fuel regulator
New fuel pump
New fuel filter
recently cleaned injectors
New clutch
new pressure plate
new flywheel
new master cylinder
new slave cylinder
New intake manifold gaskets
new valve cover gaskets
New muffler
170-172 PSI accross the board.
Great truck, work or daily driver. Gets 21 MPG. Drove back and forth to florence all summer pulling trailer with quads, no problems!!
Some minor scratches and dings. Dent in rear bumper were dad backed into me. Minor cancer around antenna. Paint wear on back of cab due to rubber gasket on canopy (stupid manufacturers). Will buy new tags before sale.
Check engine light turns on and off for some reason. codes 25 & 26. Good compression, Motor runs awesome. Must be a sensor freaking out or maybe TPS out of adjustment. Swapped out AFM, O2 sensor, and replaced many parts on fuel system. Its started turning on/off shortly after I swapped out the auto tranny (about 11 months ago). Gauge cluster growls every once in a while also.
Found a Ford F250 I want to buy. Come on over and take it for a drive, do a compression test. Whatever.
I had other pictures but I must have deleted them. Will take more upon request.
$4,000.00
My names ED
Email me: [email protected]
PM me: Use the PM button!
1981 Toy 4x4: 355/350/Toy, welded rear, detroit front, 36" tsl's, 12000# tugger, 4" suspension, 3" body, Marlins hy-steer...
Spider
Would be interested in possible trade of 90 - 95 1500/2500 extra cab chevy 4x4, 5.7L V8.
Spider
humboldtblazer
