Author Topic: All-pro superflex springs??  (Read 2646 times)
mxpro_156
  • Turtle Points: -155
  • Member since Apr '05
  • 5th GEAR PINNED
« on: Oct 21, 2005, 11:12:47 PM »
Has anyone used the front All-Pro Superflex springs? How do they work and how is the ride? I am in the process of putting Chevies in the rear of my '84 toy right now. I like the superflex spring because they are short and low lift height. Or have any better ideas? I dont want rears in front though....Also I bought Sky's kit for my Chevy swap, how tight do i need to get the shackle bolts? My friend said i dont need to get them too tight because there is a locknut but i dont want them falling off. when i get them too tight they won't move though.
Thanx alot
« Last Edit: Oct 21, 2005, 11:20:05 PM by mxpro_156 »
flyin ryan
  • Turtle Points: -204
  • Male Posts: 241
  • Member since Sep '04
  • poser to the extreme!!!
Re: All-pro superflex springs??
« Reply #1 on: Oct 21, 2005, 11:39:38 PM »
Eric Hansen of yota masters uses the 3" lift buggy allpro springs, He swears by them.  He has shown me a the difference between the regular 5" vs. the buggy lift.  I myself have the allpro 5" and they work great. Good street ride and flexy offroad.  Next time I will go marlin's because of the quality. From what I've seen,  Marlin's spring packs are nice and straight unlike my allpro, they are uneven. I wanted to sport a taller truck for coolnest factor.  If you search around you'll see eric's truck with alot of great flex.
Ryan
iNfErNaL
  • El Presidente
  • Turtle Points: 109
  • Male Posts: 7,509
  • Member since Aug '04
« Reply #2 on: Oct 21, 2005, 11:44:09 PM »
If you wanna see Eric's truck,go to  www.yotamasters.com  .It's the white 2nd gen.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
 www.RockBrawlers.com
 www.offroadtruckshow.com
mxpro_156 [OP]
  • 5th GEAR PINNED
« Reply #3 on: Oct 21, 2005, 11:48:18 PM »
alright awesome thanx alot guys. do they mount in stock location? i want to do that with sky's boomerang shackles.All-pro says their 47'' and stock is 48'' right???
« Last Edit: Oct 21, 2005, 11:55:00 PM by mxpro_156 »
iNfErNaL
  • El Presidente
  • Male Posts: 7,509
« Reply #4 on: Oct 21, 2005, 11:55:14 PM »
Hey,no problem.It's what we're here on Friday nights for...While everyone else is out partying  :rivers:
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
  • Member since Feb '05
« Reply #5 on: Oct 31, 2005, 04:55:32 PM »
I have the buggy springs in my truck. I can go flex it for you and take pictures in the next few days. The springs are longer than stock so you will need a new spring hanger. You will need bumpstops also. Mine negative arch really bad otherwise. They flex like crazy though.
gedean
  • Turtle Points: -198
  • Male Posts: 40
  • Member since Dec '05
« Reply #6 on: Dec 26, 2005, 12:00:15 AM »
I've got the superflex springs and all pros johnny joint shackle in the rear and I like them.  You have to relocate the front hanger and the rear hanger for the rear ones (just like most every other decent spring).  The ride is pretty decent as far as I'm concerned.  Eric at www.yotamasters.com does run them (the white 85 pickup) also.
2000 Tacoma 3.4 V6, 5 speed, 4.88 gears, E-locker rear, 255/85R16 BFG MT, Lefty with Marlin Dual Cases and 4.7 gears topped off by a triple stick.
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
  • Member since Jan '05
    • Buy me a cigar
« Reply #7 on: Dec 28, 2005, 04:05:33 PM »
gedean, do you think you could post some flex pics!    Please.
gedean
  • Male Posts: 40
« Reply #8 on: Dec 30, 2005, 09:10:43 AM »
Here are the pics and some measurements you asked for...
At max flex (before the truck starts to get light on the rear wheel) there is about 33-34 inches underneath the tire
I think the springs are capable of more but limited by the shocks.
In the rear I'm still running just 10 inch travel Bilstien 5100 shocks on the stock upper mount
In the front I'm running 12 inch travel Bilstien 5100s on the All Pro shock hoops
Underneath the door from the ground to the frame I have approx. 23.5 inches of clearance (35 inch MTR on 15x10 rim)
They ride well, and are pretty soft springs.  The truck does lean a little to the pass. side.  I think this is primarily from the gas tank.  If you have any other questions just ask and I'll post what I can.
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
« Reply #9 on: Dec 30, 2005, 10:30:59 AM »
 Thanks a lot for the pics, how well do the springs control axle wrap.
mxpro_156 [OP]
  • 5th GEAR PINNED
« Reply #10 on: Jan 01, 2006, 12:55:44 AM »
thanks a bunch that helps me out alot...
gedean
  • Male Posts: 40
Axle Wrap
« Reply #11 on: Jan 01, 2006, 02:36:12 PM »
I don't really have much of a problem with axle wrap.  The leaf packs have got alot of very thin leaves (eight I think, without going out to count) and the overall thickness of the pack with so many leaves works to contro wrap pretty well.  Overall they are good springs and I picked them mailnly because while some people have problems with All-Pro,those I have talked to have spoken well of their suspension components.  They also offer little lift, and are a much better engineered spring than something like a skyjacker, rancho, or downey.  I'm happy with them.
mxpro_156 [OP]
  • 5th GEAR PINNED
« Reply #12 on: Jan 05, 2006, 06:56:44 PM »
yeah i have a skyjacker 3" springs in the front and their stiff and dont flex super well. but the do pretty good for as cheap as they were $180
Last post Jan 24, 2004, 04:03:14 PM
by Thumper
Last post Jul 03, 2004, 07:01:34 AM
by lowgeared
Last post Nov 11, 2004, 03:25:00 PM
by kneedownnate
Last post Apr 13, 2005, 07:37:39 AM
by TRDISMO
Last post Apr 07, 2006, 02:19:13 PM
by twerp
