putting a 5 speed where a automatic used to be
Started by DAWGTOY, October 21, 2005, 07:50:58 AM
DAWGTOY
hey guys  i got a line on a 88 4 runner with 22re and a auto.$500.00. :yikes:
was wondering if any of you guys ever put a stick where a auto was? ???
i've got a 86 pu with a good trans and all the other parts.
seems like it wouldnt be to hard. :yupyup:  what about the computer?
everything else should bolt up right? just change the peddle
assembly under the dash.  :turtle:  :turtle:  :turtle:
just what i need. another project. :shocking:
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
DAWGTOY
Yea its an easy swap.  You'll of course need everything that goes along with the 5 speed.  The clutch hardline, master cylinder, slave cylinder, flywheel, clutch set, pedals assembly, and of course the trans and shift boots.  The hardest part of the swap is drilling the hole for the clutch master cylinder and thats easy.  Otherwise its a straight forward swap.
billy hill
You don't even need the whole 5 spd. pedal assy. Just pull out the clutch pedal and mount it in your runner. The auto pedal assy. has the bracket to bolt up the clutch pedal. At least mine did when I used an 87 2wd auto cab. Just drill out the hole for the clutch master, mount it and be done.
official mall crawlin pavment pounder #1
TigerToy
You might have to do a little floor board modification, but it is really straight forward.  I also had to do some creative wiring with the neutral safety switch.
