72 Chevy Blazer
Started by KYOTA, October 14, 2005, 07:00:28 PM
KYOTA
Posting for a friend, any questions call 503-317-5886
I will only respond to this thread to bump it up
1972 Chevrolet Blazer
1970 402 bored .30 over, cast pistons, cranked ground .10 under, rods resized, block line bored, balanced, dual pattern flex plate, Comp Cams 298H cam, Rhoads lifters, Comp Cams 3/8 push rods, ARP rocker studs, 1966 396 closed chambered heads, Manley Pro-Flow valves, Comp Cams springs and titanium retainers, 10 degree locks, lash caps, Comp Cams Magnum roller tip rockers, Pete Jackson gear drive, Weiand Team-G oval port intake matched to heads, Predator carb. Heads were ported and polished with cobalt valve seats. 4 core radiator with dual Flex-a-Lite electric fans. Extra large trans cooler, TH-350 with TCI trans brake and reverse manual valve body and a 3500 stall converter. 205 T-case with all new seals and twin stick conversion. Heavy duty drivelines, Dana 60 front (open) bought brand new was still in crate, 14 bolt rear welded with disc brakes. Aprox 9" lift with new springs front and rear. 39.5 Swamper TSL's up front, 3905 Boggers rear. Rebuilt steering pump and box, crossover steering, Flaming River steering shaft. Custom built 6 pt. cage, custom built bumpers with a Warn 9000. '03 Tahoe leather full power heated bucket seats with full 5 pt harnesses, interior completely finished in spray on bedliner material. Has an estimated 500-550 HP. This truck is set up to play or compete which ever you choose and runs best on race fuel but does run well on 91 octane also. Almost everything on this truck is new.
$6500  NO TRADES
located in Rainier Oregon
*Again, posting this for a friend* if you have any questions call Tony @ 503- 317-5886 anytime, leave message
