4.88s or 5.29s
Started by yotacrawler4, October 05, 2005, 04:28:57 PM
yotacrawler4
i want to know what should i get. I dont daily drive the truck i just wheel it. I have 35 toyos, a ppprrreeeeetttyyyyy much stock 22re, except with a free flow exhaust and a k&n filter charger kit, so what should it be 4.88s or 5.29s :thumbs:
86' yota, extra cab, duals, HP frnt with detroit 4.88s, V6 rear with detroit 4.88s, bobby super set, driveline tech dl's, neat lil upgrades on the way can someone say 4link and dovetail front...
With 35's 5.29's would make it about stock ratio, but I don't like how small the pinion is with the bigger tires so I'd go with 4.88's
yotacrawler4
well i think on 4 wheel parts .com they have the ratio chart and it says 4.88 or more stock then the 5.29s, they say the 5.29 or more for the more competive stuff or something :dunno:
Anthony
Quote from: yotacrawler4 on October 05, 2005, 04:39:50 PM
I wouldnt go by anything related with 4wheel parts. They just tell you what the computer says. Call Randy's ring and pinion.
Quote from: Anthony on October 05, 2005, 04:44:54 PM
4wp's would not be my choice for information either, 4.88's would be slightly high for 35's and 5.29's would be a little low.
yotacrawler4
o believe me i dont but i saw that on another website not just 4wheelparts
IronClad
we're runnin 5.29s with 40's...   still cruisin up hills in 3rd  on a 22r.   get 5.29s .. were bout stick *gasp* 5.71s into a buddies truck (same truck with 40's) to get a little more gearing
Annihilation  Fabrication
Do you need a Hammer?
mudmaster
got 5.29's with 36's, no problems
Time to go wheelin!
I have a feeling the same people that swear 5.29's are junk are the same ones who are busting knuckles and steering arms with hydro assist.  They take their lack of forethough to limit the ram's travel and blame the parts for the breakage.
Im anythingbut shy about the stupid pedal and I have yet to break a gearset.  Just get quality and be done with it.
Quote from: WHITE_TRASH on October 05, 2005, 06:08:19 PM
You could be right, I've heard it both ways and err on the side of caution and went with 4.88's on my 4Runner and 84 Truck, well and my 85 truck, um and my 86 extra-cab and of course still have my stock gears in my 80. I have seen that pinion and it is a little small and the ring is really big, so big that you must grind the notch to get it through. With the 4.88's you just need to spin it as you put it in the housing.
I didnt have any issues with getting mine into the housings.  Im funning a 79 front housing and 94 4 cyl rear.  Both of the diffs (front high pinion, rear 4 cyl) slipped right in.  The front did need to be turned a bit but I didnt grind anything at all.
yotacrawler4
so both of you have 4.88s in your rigs
Duffil
I've driven a rig with 5.29s and 35s, a little low, but not bad.  I run 4.88s, but then again, I have 31s, also :gap:
Hah, nope Im runnign 5.29's in my junk.  I ran 4.88's in my 84 for awhile but I dont recall having any issues getting them in.
yotacrawler4
well what would u rather have for trail rig 4.88s of 5.29s cause i already have a daily friver 2wd yota so i dont need to worry about on road use
On every vehicle I put them in (4.88's) I had to spin the gear as I fed it in, and people that I've talked to that had 5.29's have said they needed to trim the ring notch on the housing to get them in. Maybe they didn't try to spin it in like you and I have done. :dunno:
Id go with 5.29's if it'll ever see any road time.  Im running 38.5" sx's on mine and I drive it quit a bit onroad with no real acceleration issues.
yotacrawler4
so u think i will have accel issue's with 4.88s, but im just more worried about whats stronger also :turtle:
Either one will be strong enough for what you want to do.  Personally Id put more worry into the brand of gear I run vs. which one is stronger.  Cheap gears are weak wether they are 5.29's or 3.90's.  ;)
Quote from: yotacrawler4 on October 05, 2005, 06:38:22 PM
Well of course 5.29's would be best in gearing and since I've never tried them only from what others told me before if someone like WHITE_TRASH has them on 38.5's with no issues I would even be inclinded to go with 'em on my truck.
I think that 4.88's and 35's are better then 5.29's.  I have 5.29's and 37's right now and like it.  but when i had 35's i thought it was a little low for the road.  Great for the trail.  But if i were to do it again i would go with 4.88's just because they are a little stronger.
yotacrawler4
thank you lots that what i wanted to here  the hole time :beerchug:
hudlenutz
Grimm's Ratio Calcs:  best place to start when you're thinking about gears   :yesnod:
http://www.dfw-tx4wd.org/Tech-Dept/Tech-Dept/gears.html
mudmaster
I agree with WT, go with quality and you won't have a problem.
Time to go wheelin!
