signs of the failing TPS
Started by yotacrawler4, October 05, 2005, 04:20:44 PM
yotacrawler4
what are the signs of the TPS failing or is bad? :turtle:
86' yota, extra cab, duals, HP frnt with detroit 4.88s, V6 rear with detroit 4.88s, bobby super set, driveline tech dl's, neat lil upgrades on the way can someone say 4link and dovetail front...
4.3s10
I'm pretty sure your throttle starts acting up like having dead spots or the throttle is just way out of wack. A way to test is you take a digital multimeter and see if the voltage goes up smoothly when you rotate it if it jumps around then its bad
1990 s10
4.3 bored out .030
Dynomax cat back
tbi spacer
Flowmaster delta 50
Holley 670
Accel coil
2 add-a-leafs
yotacrawler4
ok when u check it is it with the key to the on position and the tps plug off of it of what?
4.3s10
1990 s10
4.3 bored out .030
Dynomax cat back
tbi spacer
Flowmaster delta 50
Holley 670
Accel coil
2 add-a-leafs
