lock it
Started by yotacrawler4, September 29, 2005, 06:43:46 PM
yotacrawler4
i have heard to not use a spool if u tend to drive the trail rig alot on and off the trail because of the pressure it puts on your axle and it tends to were them out faster, is this true or not and if it is what locker should i get so i dont have this type of problem and have to replace bearings and all the crap :turtle:
86' yota, extra cab, duals, HP frnt with detroit 4.88s, V6 rear with detroit 4.88s, bobby super set, driveline tech dl's, neat lil upgrades on the way can someone say 4link and dovetail front...
*FFC*
I ain't never heard nothin of that :headscratch: and I'mma spool my rig purty soon here.... :dunno:
yotacrawler4
cause on the marlin site click on spools and its says not recommended for on road use, or it might be all pro offroad
toynorcal
Quote from: yotacrawler4 on September 29, 2005, 06:43:46 PM
On the trail you won't have any problems or draw backs using a spool. For daily drivers, this is probably not the route you want to take for a traction device. It will add stress to you axles and cause more wear on your treads. This is bacause your outer tire travels farther in a corner than you inner tire. With the spool installed both tire are going to traver the same distance all the time. That means alot of torque for the inner side of any turn on pavement. If you want a daily driver traction device a spool will work given its draw-backs, but you may want to look into a Limited Slip type locker.
yotacrawler4
thats what i mean, then would a detroit work well, im not driving a tone but i still want to keep my axles in good shape
Rockcrawlintoy
my buddy brenden wore a spool out. the spines on the axle and on the spool were wearing guess thats what a big block does to a 9 inch
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
toyrokcrwlr
Get a Detroit locker, I know its a little pricey, but in the long run its the right choice.
I've had on my rig 8 years now, My truck is an 1988 V6 and i put the detriot in 1997 with the gears and same whole rear end and never had any problems. I love my detroit.
*FFC*
Quote from: yotacrawler4 on September 29, 2005, 06:55:59 PM
D'OH :smack: of course not recommended for on road use. Have you ever heard a vehicle with a spool tryin to turn a corner? Not only does it hurt yer tires a lil bit, it greaters yer risk of rolling.  Since both tires HAVE to spin at the exact rate, instead of pivoting like a limited slip or something... make sense? plus... what toynorcal said :thumbs:
yotaboy79
ah hell my toys me daily driver and its welded in the rear its not gunna wear your axles out unless your realy hard on it and perpusly trying to break somthing but you will have to replace your wheel bearings a little  more often and it does where your tires down quicker
HOODLUM
#9
The only vehicle I would never even cnsider putting one in is a 1/4 car(drag racing) spools are desinged for going in a straight line not for the road. Ever see an axle remove itself while driving down the road? it's funnier than hell as long as your not the owner. :haha: Your better off with a cheap locker. This is just my opinion. BTW this also does beat up your ring&pinion as well.
99 TACO 2.7 4CYL  HP d-60 front d-70 rear 5:13's and detroits 63" chevy rear springs second gen rears up front.
http://rightcoast4x4.com/
TEXXX
for a good inexpensive locker go with a aussie locker (www.offroadlocker.com) Ive heard good things about em.
RIP Gatekeeper you will be missed!
over_rev
 I run a Spool(rear) In my DD w/37's.........The only Issues I have is:
     1,The 3rd wants to stretch the studs for the 3rd member,Its fine on the street but everytime I hit the trail I have to retighten the studs(im thinking on going with a larger stud and mod the 3rd)
     2,When turning sharp your tires will be chirping worse than a Welded or detroit Loker.
   No tire wear issues Ive had the tires on since april and Im still around 85% on tread.....
Pak It In Pack It Out!!
