my zuk or is it toyota?
Started by zuknstien, September 28, 2005, 08:36:48 PM
zuknstien
Specs 86 suzuki samurai body and frame
89 toyota 22re
83 toyota axles
CV drive shafts front and rear
L52 transmission and top shift tcase
86 ifs toyota box with high steer
toyota steering column and guages(with tach)
K&N air filter, heddman header, flowmaster.
35" bfgs
4.10 diffs! yeah it halls ass on the flats :P
86 zuk
89 22RE(in zuk)
power steering with high steer
toyota axles
waswheeloverhondas
didnt i see you at the high lakes last year with a black sami and it had the benz deisel??
i liek the sami, lets go up to the high lakes :beer:
-Hans
Woah, how does that engine run? I've always had problems when those older AFM boxes are mounted at even a slight angle. That trapper door that operates the internal potentiometer is heavy, and in that position, I would say that your engine is running rich when you are any partial throttle.. What do your plugs look like? You might want to check them out- I am pretty sure the AFM should be mounted as horizontal as possible....
As for the Zuki, it looks killer man! I have thought about building one and turning it into a buggy, but I don't have the time nor resources for that yet..
Now all you need is a Crawler and you're set! :beerchug: :yesnod:
Cheers :beer:
zuknstien
the old motor 72 benz 240D I bought the zuk with it.
the motor seems to be running fine but I have only had it going for a few weeks. there was really no way to mount it right without loseing the box and Im pretty sure I have to have it to pass smog I might rig it right for the inspection and then stick a cone filter on it
86 zuk
89 22RE(in zuk)
toyota axles
motorider228
awesome sammi, lets see some action pics now  :yesnod:
whiteman
Yes that sammurai is sweet.  i want to do the same.  How about some flex pics.
zuknstien
I will be taking it up to the high lakes oct 15th, you can find me by following the cluch smell
86 zuk
89 22RE(in zuk)
toyota axles
zuknstien
changed it around for now, will have to put the air box back on when I try to smog it, if I cut the bottom of the air box off do you think the smog ref will freak?
86 zuk
89 22RE(in zuk)
toyota axles
whiteman
That motor dosent look to packed.  Looks good.
toyoder
got some 4.7 gears! there inchworms only the best! haha yeah right! :turtle: all the way
zuk tube buggy
22re powered
zuknstien
oops, I posted as him he uses my computer some times I forget to check if I'm logged in as him. in the middle if installing the gears.
86 zuk
89 22RE(in zuk)
toyota axles
zuknstien
the posershot that was requested. it will do more I but I dont have anything bigger.
86 zuk
89 22RE(in zuk)
toyota axles
zuknstien
86 zuk
89 22RE(in zuk)
toyota axles
zuknstien
86 zuk
89 22RE(in zuk)
toyota axles
4DEES
is that a MCR4 sticker I see on your tailgate??
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
4DEES
zuknstien
yeah it is, the rig was not there but I was.
86 zuk
89 22RE(in zuk)
toyota axles
