60s in a 3rd gen.
Started by Tweeked89, September 15, 2005, 12:04:27 AM
Tweeked89
Hey all, i just recently picked up some 60s for my toyota, have had it for little over a month and already went to SAS with Toy diffs and bumpin up and be done with it with 60s front and rear. both stuffed with 4:56 gears, spool rear, welded front with hydro assit. here some pics, currently setting on 37" SSR :hammer: , should have 40" Iroks on by thanksgiving time. here some pics of where im at now.
BEFORE
AFTER
W.H.O.R.E. founding member
-My G-Ride-[/b]
89 Ex-cab Toyota, V6, Locked Dana 60s, new 39" IROKS, kinda built kinda not
That's awesome :bowdown: So is this an Automatic I hope? 4.56 + 37" tires with 5spd = :yikes:
70 MPH would be like 2300rpm with 40" tires.. My 3RZ could not do that for sure
Tweeked89
Quote from: BigMike on September 15, 2005, 12:05:36 AM
nope shes a 5spd with a 3.0 V6, its going to be dual cased with a Dana 300 later
-My G-Ride-[/b]
TOYJOETA
What did the 60's come out of Dodge or chevy :dunno:
Thanks
Joe
6.72:1
How do you folks get 60s? I want some.
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
go to a junk yard and look for a 4wd 1ton chevy or dodge truck
Quote from: Tweeked89 on September 15, 2005, 12:09:58 AM
your going to wish you had 5.29's
1tonCroozer
Actually....5.38's. 5.29 is a yota axle ratio. ;)
toybuilt
I have 4.56 gears in my 60 and 14 bolt, but I'm also putting in a chevy V6
1983 Toyota Turned Chevy
Tweeked89
these 60s came from a 78 chevy k30. 4:56's arnt so bad plus it has the chain driven t-case that gives it alittle more low ratio, thats gonna need to be replaced with dual cases with a 300 and twin stick. update, bobbed the bed 16" today. just need to weld and bondo it up.
-My G-Ride-[/b]
6.72:1
[email protected]
Tweeked89
update, ended up trading crap for a complete 60, here are some current pics.
-My G-Ride-[/b]
seanc
looking good! lets finish it soon!
You win some, you lose some.
toybuilt
Lets see that front end bolted up already. :biggthumpup: Looks good, keep it up.
Tweeked89
Quote from: toybuilt on September 25, 2005, 10:54:20 PM
takes time, need to build the wider spring hanger and build my offset shackles. picking up my new 39" Iroks in about a week or so. seanc get gas tomarrow and will see you in the afternoon to knock this thing out.
-My G-Ride-[/b]
gotrocks
Tweeked89
outside to outside will be 35", center pin is 32"
-My G-Ride-[/b]
toybuilt
going chevy wide in the front, what kind of springs are you running?
Tweeked89
toyota rears with a mix of Land Crusier lift springs
-My G-Ride-[/b]
Dazz
So you kept the stock D60 width and didn't narrow it?  8)
I'm doing the same with mine, but I will be running a DRW D60 front and keeping it stock width with stock Hummers BL.
Post some closeup pics of the front spring hangers when you get a chance!
:beerchug:
RHG
Why go through the pain of finding a D60 and then narrow the thing? Too expensive, youd be better off getting a custom setup from Dynatrac or something. I think most people go with the 60 specifically for the width, and the possibly the weight. Oh and by the way....I like it! Fullwidths look fawking awsome on a third gen.
Tweeked89
thanx guys, got my 3.0 EFI running today (thanx SEANC!) and also got my new 39" IROKS also. spring hanger will be built tomarrow and maybe have the front end on its weight. also bobbed the bed more, wheelwell to cab is 6", took out 7". shorter WB for the tight trails
-My G-Ride-[/b]
seanc
no prob paul. i love working on engines! don't forget to change your sig line to include the new 39.5" rubber! Paul and i are fabbing the front crossmember as we speak. will be on wieght soon!
Tweeked89
updated pics.
-My G-Ride-[/b]
Northern Runner
what size rims are you running?
Tweeked89
-My G-Ride-[/b]
toybuilt
How short is you bed length now, or how much did to cut out of both sides?
Tweeked89
i believe the total on the bed is 20" cut out. not sure what the total length, bottem of wheel well is 4" away from the back of the cab.
-My G-Ride-[/b]
RHG
I like the green :eyebrow: Gives me an idea of what to paint my shackles and sliders. Maybe, we'll see
toybuilt
The green does look good. do you know what your wheelbase is yet?
