Well i finally checked the refrigerant charge and it was fine. I found that at idle, when its not cooling, the rpms will raise up but the a/c clutch wont engage. then other times nothing happens. I
think its a a/c relay by the glove box. If i beat on the heater housing under the glovebox the a/c will work again
![Order order! :_order:](https://board.marlincrawler.com/Smileys/marlin/_order.gif)
. I just need to open it up and find out which relay has the bad contacts
hopefully this will fix it.
