Gear Set-up
Started by seanc, August 29, 2005, 11:32:51 PM
seanc
ok so as i build aa front axle i wold like to take a crack at setting up gears. i plan to put 4:56's in. i was wondering if any one could recommend a gear vendor to buy from. i assume marlin's are good. also ease of set-up is what i am looking for. and what else will i need. i have a dial indicator with magnetic stand, and torque wrenches. i have found several write-ups. no toyota ones though. but i get backlash, and gear pattern. thanks in advance.
You win some, you lose some.
mr4x42u
marlin sells youkon gears,,wich I have found to be better gears...the lifetime warranty gears just don't seem to hold up to the beating thatthe youkons do...once you get them you can have bobby cryo them for chep..
Toyminator
Zuk's site is a great resource for setting up Toyota gears.
http://www.gearinstalls.com/
FIREBALL
The yukon gears come with directions including torque, backlash and pattern specs. A shop press is very helpful too.
Tweeked89
i got a press lined up for ya sean
W.H.O.R.E. founding member
-My G-Ride-[/b]
89 Ex-cab Toyota, V6, Locked Dana 60s, new 39" IROKS, kinda built kinda not
