R151 transmission thoughts
Started by fzj40, August 18, 2005, 05:55:10 AM
fzj40
 :red_eyes:
OK, here's some random thoughts.  Can a late model (96+) R151 with 7.5" input shaft be used with an R154 bellhousing and a turbo clutch behind a 7MGTE?  This would require a JDM R151 from a 96+ Hilux or LC that had the 22R/7M standard bolt pattern on the block side of the bell.  I think the KZTE has this?
Also, if the thick chevy camaro flywheel was used behind a 7MGTE with a 7MGTE clutch and AA pilot bearing, would this allow the use of an early 6.5" input R151 with an R154 bell and turbo clutch?
Just a couple of thoughts.  Maybe Marlin knows? ???
jr9162
The late (190 mm or so) 7.5" input shafted R150F from a 96+ Toyota (from behind the 3.4 liter v6) will probably work with a 7M-GTE bellhousing if you use a custom pilot bushing to support the input shaft. I believe the R154 gearbox has a slightly longer shaft than the late R150F. However this late R150F also has a chain driven Tcase with driver's side drop/front output.
I'm also thinking that the R150F and R151F's in Asia (OZ) found behind the turbo 2L and 1KZ-T or 1KZ-TE trucks/4Runners are passenger drop, chain driven Tcases. But they also have the same 160 mm (6.5") input shaft as the R151F found behind the North American 22R-TE trucks.
The thicker Camaro flywheel was used in conjunction with a 60 degree Chevy 2.8, 3.0, and 3.4 liter v6 in an attempt to adapt a R151F converted with a AX15 input shaft assy. This flywheel has nothing in common with a 5M, 6M, or 7M engine.
The 22R and 7M block to bellhousing bolt patterns differ, and the starter is also in a different location. One can not bolt a 22R bellhousing to a 7M block.
JR
I'm a member of P.E.T.A.
People Eating Tasty Animals
There's no nookie like chinookie
No butts like halibuts
Fish are not our friends, they're food.
Eat more moose - 10,000 wolves can't be wrong
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed Pharmacist".
