22re acceleration problems
Started by horshu, August 17, 2005, 01:48:53 PM
horshu
Someone please help me.  I can't find a single shop in Virginia that knows Toyotas.  I just put a new long block 22re in my 89 runner and after replacing the maf and having the distributor out several times i can't figure out my problem.  When i accelerate it feels like something is holding back, no power.  Feels like timing, but i cant get it right.  It actually feels like it picks up better when you let off the pedal.  More pedal, less power????  Doesn't sound right.  Someone help!
whiteman
My 86 runner does that and I keep cracking distributor caps.  I replace the cap and it runs good.  But it still does the same thing only when its raining out?  ???        Sorry man i have no clue,  some here have told me it is my EGR valve or some sensor. :dunno:
I bet if you're real sweet to Reklund5 he might offer some insight.
Whats the timing at?  Is the cam timng correct?  What happened to the old engine, did it lose a head gasket?  When was the last time you changed the fuel filter?  Did you screw up the vacuum lines?
mcfly
Is the throttle position sensor set correctly?
horshu
Quote from: WHITE_TRASH on August 18, 2005, 12:39:50 AM
lost head gasket, head fused with block... Bought new long block fuel filter mas reused accesories(?) and set timing according to sticker under hood
horshu
zeke
i had this problem on my 85 for a while first i found out i had a vaccum leak the the heads were not all firing and timed right then i cleaned out my fuel injection and it has been fine ever since so see if any of those are the problems if not ya got me?
