Author Topic: FS/Trade: Dana 44 fronts for toyota  (Read 1855 times)
Pat
  • Trade Count: (0)
  • Turtle Points: 786
  • Male Posts: 944
  • Member since Jun '02
  • Oroville, Ca
« on: Nov 12, 2002, 05:29:19 PM »
I am getting rid of all my Dana 44 stuff. all chevy six lug passanger drop standard cut,,,. I have one pretty much complete 44 but in pieces .. FLAT TOP KNUCKLES pass side not milled and drilled yet. spindals hubs calipers, rotors , backing plates,and so on. Plus I have almost another 44 but I know I am short a axle or 2 and it has no knuckles. stock gears 3.07?. As far as the housings There are 2.. Both full width now but I will narrow one 2 62 inches and ROTATE KNUCKLES FOR BETTER PINION ANGLE and set it with toyota spring pad width.. I have a full set of u bolts with the ubolt plates this would make a great set up for some body wanting a wider 44 for a toyota plus you would have some spare parts for when you break Gettin it!!! I will also make your tie rod and drag link for them once you are ready to put your steering on.. Supply me with DOM .. I can drill and tap them for Chevy one ton ends I want $$$$$$400.00
BTW.. at 62" you would need to get 2 junk yard axles .. wagoneer short and dodge long I believe.. or visa versa.. so it make it nice to have stock type axle to replace with..no custom stuff
Stuff I am willing to trade for...
TOYOTA front axle
Toyota diffs 4.88's or maybe 4.56's or 5.29's
toyota lockers?
toyota high steer arms, skys, kongs, ott's only
« Last Edit: Dec 31, 1969, 04:00:11 PM by -1 »
Sharing time between Northern Ca and Western Tn..
superonaldean
  • Trade Count: (0)
  • Member since Jan '03
  • I love Marlin Crawler!
Re: FS/Trade: Dana 44 fronts for toyota
« Reply #1 on: Jan 23, 2003, 01:07:39 PM »
hey there do you still have the 44's i have toyota front and rear axles with arbs in them and the compressor that i am going to be getting rid of. if you still have them let me know and maybe we can work something. thanks
ron
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
yota83
  • Trade Count: (0)
  • Turtle Points: 40
  • hammer down !!!!
« Reply #2 on: Jan 23, 2003, 01:50:45 PM »
i have a set of 79-83 toyota axles with 5.29's, welded rear, tru-trac front with three runs on it and new R&P.....
im in the bay area so i will pick the axle's up...
so ill give you everything in trade.. lockers, gears and axle's??????
« Last Edit: Dec 31, 1969, 04:00:01 PM by -1 »
i cant remember!!!!!
CRAZY PEOPLE ARE NEET!!!!!
wheeloverhondas
  • Trade Count: (0)
  • Member since Aug '02
  • MY CAMEL HAS NO HAIR!
« Reply #3 on: Jan 23, 2003, 03:07:43 PM »
hey super ronald, ive got some 3/4 ton axles ill trade you, dana 60s
87 xj, dana44/60, welded front and rear,hysteer being made,38s,and lots more
Last post Sep 03, 2002, 03:49:34 PM
by crawling82
Last post May 03, 2005, 08:11:45 AM
by TrackVino
Last post Jun 30, 2005, 09:27:44 AM
by toybuilt
Last post Apr 11, 2008, 04:37:27 PM
by *** YELLER ***
Last post Oct 15, 2011, 05:48:12 PM
by toysfreak
