dug up from the grave... so what is all the hype about the twin stick. What does it do and can you use it on a single case? I think i want one but not sure exactly what is does. But i wanna know if it does anything on a single case. So if you put it on a single 4.7 what would t do for ya?
so then it it pointless to put on a single case, cause if you just dont lock in your hubs you can run 4low rwd. why cant you do that with duals or you can but people dont. I am not getting what is so good about them? to be 4wd you have to lock in your hubs otherwise you are 2wd. put the case in 4low and there you go 2wd 4low.
Started by firemanjohn General 4WD Discussion
Started by BLACKDOG General 4WD Discussion
Started by toyotajoe Parts For Sale
Started by toyotaboy Parts For Sale
Started by TBob Parts For Sale
