Drum Brakes...on IFS axles
Started by Matty, July 23, 2005, 09:59:27 PM
Matty
i know the drums are smaller on 85 trucks than from 86 and up, and i checked pirate faq and couldnt find what the actual differences are
so basically what is the measurement on a 85 and before truck drum and a 86 and after drum....
appreciate any info...thanks
decyfer
pulled this off of pirate faq. you must have scanned over it.
Axle info - Toyota
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, SA Hubs
58.25" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, IFS Hubs
63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers
'86-95 IFS front end is about 58.5" wide
'93-98 T100 IFS front end is about 65" wide
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
is it bad when you unplug the power wire from your stereo and it still plays
decyfer
 :confused:  whoops. i guess i should have read that better. sorry
Matty
its all good...at least you were tryin to help
it is appreciated
Duffil
if i understand the question, then it's 2 3/4--3 inches.
lilbuddy
Yeah I think its 8" brakes vs 11" Brakes
RIP Kyota.... you are the man
GET IT!!!
