40 spline Birfs
Started by surfindave, July 13, 2005, 07:00:10 PM
surfindave
Hey guys i was readin a topic on pirate and Chis geiger said they are waiting on some 40 spline birfs from newfields ?
Have you guys herd anythin about these?
Dave
HFCRAOffroading
40 spline?  In the birf joint only?  Would have to be, I don't know of a hub that will take a 40 spline unless Marlin makes a 40 spline flange.
CTENG in KS
Haven't we already reached the point where the 30 spline birf is killing hubs and ring gear?  What is the 40 spline gonna do other than be more expensive?  And if these get too much more expensive, and you wanna run big meats, then isn't it more cost effective to just go D60 to start?  I am all about beefing my toy axle for 37-38 inch tires just because of the weight savings, but if I am going 40's or bigger, I'll be hookin up a 60 or truhi9 under my rig.
MiniSimp
CTENG in KS
surfindave
Yer its just what i saw but the 30 spline will do for me as i only run the 35s maybe go 36 at the most
Just was curious as to how they would fit?
Anyone got pics for an exo cage on a 2nd Gen 4runner getin a bit too much panel damage ?
Thanks Dave
MiniSimp
Quote from: CTENG on July 13, 2005, 08:52:40 PM
:headscratch:  to you too!   :greengrin:
Just wondering what the point would be...r&p are breaking now with 30's...
CTENG in KS
 :werd:
surfindave...thats an easy one, search marlin and the pirate toyota board for exo*
You will get responses up the wazoo.
Marketing
CV unlimited is working on a new design that is expected to be similar to the 30 spline joints Bobby sells. If testing goes well we plan to carry these axles and joints. We do not have prices or timeline on this.
mr4x42u
Quote from: CTENG on July 13, 2005, 08:44:48 PM
this was my point..what would be the point,,hubs a nd gears already are an issue with the 30 splines..40 is just overkill..
RHG
i was thinking about going w/the 30 longfields someday and I seen that they can also cryo your r/p gears. Whats next? I guess the next weak spot is hubs? Ight, then somebody needs to come up with some bulletproof hubs. Just playin...it'll never end. But for real has anyone run a r/p thats been cryoed? Lets hear some opinions and feed back.
mr4x42u
with the 30 splines,,,hub flanges,,4 dowl hub pins,,arp hub studs and a cryo ring and pinion your going to have a really stout front end,,and with a bigger ring and pin like 4.88 or higher it only gets stronger from there..on a light rig its going to be almost bullet proof..
CTENG in KS
I still see myself running the 27 splines...if they get to be too weak, then I will bump up to the 60...
MiniSimp
Quote from: CTENG on July 14, 2005, 11:31:53 AM
:imwithstupid: Chevy 60's & Hendrix Chassis will be the next step.
CTENG in KS
Quote from: MiniSimp on July 14, 2005, 12:48:04 PM
Don't make me come over there!
I would be interested in the F-toy chassis, that would reduce a lot of weight too, make those toy axles last longer, plus you could compete!
MiniSimp
Quote from: CTENG on July 14, 2005, 12:50:24 PM
You can only compete if you keep the Toy axles.
Here's the rules:
Engine
Toyota 20r, 21ru ,22r, 22re engines are allowed
Propane Allowed with 5 point penalty per event
EFI allowed with 5 point penalty per event
No penalty for rigs running carburetors
All Motors Must:
Must use factory head - for block
Must use stock type carburetor
Must use stock type intake manifold
Must use pump gasoline
Must be naturally aspirated
Radiator must mount in front of engine
Electric fans allowed
Engine can be moved back 0"- 8" from stock
Engine can be moved down 0"-1" from stock
Transmission /Transfer case
Any Toyota make or model manual or automatic transmission
Any Toyota gear driven mini truck case or combination of cases
Any manufactures gear set.
Any gear ratio
Dual case adapter adapter must be commercially available
Cage / Chassis / Body
Safety cage built by an approved vendor
Frame must be Toyota Pickup or 4Runner frame, 2wd or 4wd
Steering
Any manual or power steering box.
Box must be attached to main frame rail
Drag link must attach to pitman arm on steering box
Ram assist steering is allowed
Any aftermarket high/cross over steer kit allowed.
Steering must attach to stock steering arm location using the stock method
Front axle
Front axle must be from 1979 - 1985 Toyota Pickup or 4Runner
Aftermarket birfields allowed
Aftermarket inner axles allowed
Any Toyota 8" third member allowed (FJ80, V6 or 4cyl)
Any factory or aftermarket ring & pinion gear sets
Must use oem Toyota Pickup/4Runner knuckles
Differential shaving allowed
Trussing and diff armored allowed
Birfield eliminator kits not allowed
Rear axle
Rear axle must be from 1979 - 1995 Toyota Pickup or 4Runner
U-bolt flip allowed
Aftermarket axle shafts allowed
Lockers
Any aftermarket locker
Open or welded differential allowed
Front suspension
Any conventional 1/2 elliptical leaf spring allowed
Attachment methods must be oem style, fixed at one end and a single shackle at the other end
Any aftermarket steel non take apart shock.
Shock must attach to axle in oem fashion
No traction bar or link type attachments
Springs must be mounted so they are stock width apart
U-bolt flip allowed
Rear Suspension
Attachment methods must be oem style. fixed at one end and a single shackle at the other end
Frenched spring hangers allowed
Inboarding of springs allowed
Springs must be mounded no closer together than front stock spring width
Single traction bar allowed
U-bolt flip allowed
Brakes
Any year Toyota front disc
Any year Toyota rear drum
No cutting or turning brakes
Functional parking brake or micro lock
Battery
Any spill proof style battery
Battery must be securely mounted, no bungee cords
Tires
Any tire
Any wheel
Internal or external beadlocked wheels permitted
Fuel system
Stock tank or fuel cell
Fuel system must either be closed loop system or spill proof roll over valve.
Vehicles that leak fuel will not be allowed to continue with competition until the issue is fixed.
Safety
D.O.T. approved helmet
Four point seat harness
Window net
Metal roof must cover entire roof opening
Solid metal roof can be bolt on at least every 12" inches
Expanded metal roof must be welded at each contact point
First aid kit
Fire extinguisher
CTENG in KS
My runner would qualify, I'd just be taking penalties for 22re.  I think this may be my route if I kill the bady too bad.
Makman
Quote from: mr4x42u on July 13, 2005, 10:19:02 PM
Do we actually know how much larger these 40-spline shafts would be?  Spline count does not = diameter without more details.  Splines typically have a module classification (module = # teeth/pitch diameter in mm), per DIN 5480, but I think ANSI and the Japanese are all similar.
Basically, a 30- and 40-tooth spline can be directly compared if they have the same module.  More teeth equals larger diameter.  My guess is that a 40-spline is going to be a little bigger but really gains it's advantage with more numerous and smaller teeth effectively making the minor diameter of the spline larger.  Coul dbe good marketing or like stated above, overkill given the drivetrain it's designed for.  I want to see one either way.  :greengrin:
If it never breaks, people can only speculate how much it was overbuilt.
6.72:1
Quote from: rocks hurt good on July 14, 2005, 03:40:21 AM
I have cryogenically treated ring and pinion both front and rear and they are glorious!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
