Reply #2 on: Jul 02, 2005, 09:26:40 PM »
This is a common problem on the early trucks.
1. Check for a worn or missing trans handle seat or socket.
I invented a heavy duty replacement seat and socket--they are on my web site.
2. T-case handle could be installed 180 degrees backwards.
If all else fails, remove the t/case handle, mount it in a vise and then slide a section of pipe over the handle and bend it as required.
Using a torch is not advised due to the two piece vulcanized design of the handle.
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
