Not a normal 86 build
Started by Nb86yota, November 13, 2022, 11:31:57 AM
Nb86yota
Hey Guys
I bought an 86 Pickup a few months back. I purchased it with the plans to build a one of truck. The frame was in typical shape for a truck living in Eastern Canada. I traded a 99 4Runner I had to a friend for a new 2000 Tundra frame. My plan is to shorten and thin then frame to work with my reg cab truck. I have cut the frame and have already started putting in new cross members. Been taking pictures so I will be posting lots in the future. My plan is
1986 Pickup with a 22re swap
2000 4door Tundra frame
1985 solid front axle with Chevy 63" swap in rear.
I will be making all of the spring mounts, body mounts, cross members and all the other modifications myself.
Looking forward to building this and sharing with the forum. Thanx
OVRAROK
Sounds different. I like it. Pics..
Gnarly4X
OMG!!   Another amazing FABINATOR!! ... Addicted to the smell of hot metal sparks and fondling his little mig gun!  :rofl:
Gnarls. :usa:
Nb86yota
For some reason, I am not able to post pictures at this time.
toyodaaddict
Quote from: Nb86yota on November 13, 2022, 12:57:40 PM
I think you need like 10 more posts.
Nb86yota
Yeah. I got a bunch of photos already. I had to cut 25 1/2" out of the frame rails. I the removed all the factory cross members. I had to thin the frame by 10 inches. Used the factory transmission cross member as a starting point. Cut 5" out of each side and went from there.
Nb86yota
Next I removed all the body mounts and the have been moved forward 6" to make them line up. I am not going to use the factory body mounts on the cab. My plan is to weld in 2x5" tubing for the rockers and put the body mounts on those.
a1gemmel
Can you make a build thread in the "Project Research and Build-Ups" sub-forum? I'm very interested in following this.
You can also upload your photos to Imgur and embed them here.
1981 Pickup - 35s, 5.29s, W56, dual ultimate, e-locker front, grizzly rear, 22R stroker, 3 linked on airbags
Nb86yota
I am going to be making a complete detailed build thread. I have lots of pictures and will be posting everything as I go.
Nb86yota
Will be going with small 35" tires. It's all you need here in New Brunswick
Nb86yota
I have an ARB air locker for the rear. Leaving the front open.
Nb86yota
Nb86yota
Nb86yota
Nb86yota
Nb86yota
Frame is completely shot.
Nb86yota
Nb86yota
More pics and the new frame being cut in half to take 25 1/2" out. Started welding all the holes closed so it's sealed.
Nb86yota
Follow the build on the PROJECT RESEARCH/BUILD UP PAGE. THANX
