Ummm... Is your battery dead?Do a voltage check to be sure it's OK.then check all your connections and clean them as needed, Battery, starter etc. Be sure to check your ground wires as well, as they can be the culprit.If that doesn't do it, pull the starter, and git it tested at any auto parts store (should be free).I seriously doubt mis-wiring two cylinders is going to fry anything in the ignition, especially the coil. This would affect it's ability to start. Shouldn't just click and not turn over. That suggests battery or starter.Good luckErik
Checking the starter is free just make sure the idiot behind the counter isnt one, and knows how to hook it up right
Started by Skinny_Pedal « 1 2 » General 4WD Discussion
Started by Rocksurfer « 1 2 » General 4WD Discussion
Started by brockbuilt85 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by airborne_w « 1 2 » Newbie Questions
Started by Gillesdetrail Transmission/Clutch
