Author Topic: Beadlocks  (Read 22194 times)
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: Beadlocks
« Reply #60 on: Jan 11, 2006, 06:58:35 PM »
I used steel shot in mine, not sure of the size but theyre bigger than bbs. Mike the hardest part of doing my beadlocks was unmonting and mounting the tires!
gotrocks
  • Turtle Points: 107
  • Male Posts: 2,653
  • Member since Dec '04
  • FLOOR IT!!
Re: Beadlocks
« Reply #61 on: Jan 27, 2006, 06:38:05 PM »
did you do the mounting yourself at home?
KYOTA [OP]
  • Wreckin Ball '09
Re: Beadlocks
« Reply #62 on: Jan 27, 2006, 07:30:59 PM »
yep piece of cake with a couple of prybars
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
  • Member since Jan '05
    • Buy me a cigar
Re: Beadlocks
« Reply #63 on: Jan 28, 2006, 09:04:51 AM »
Have you had any problem with loosing air over periods of time, other than what might be caused from temperature changes?
And how many cop's have asked if those are real bead locks :gap:
I am thinking about doing the same with my wheels to, any recommendations?   :dunno:
KYOTA [OP]
  • Wreckin Ball '09
Re: Beadlocks
« Reply #64 on: Jan 28, 2006, 10:07:10 AM »
mine dont leak, just gotta have good welds w/ no pinholes, the only time they get low is when i air down to 2-3lbs  8)
never had a problem
nothing that hasent been covered in this thread already
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
Re: Beadlocks
« Reply #65 on: Jan 28, 2006, 10:34:49 AM »
Thanks, but I have just one more.
How about the inner bead, do you lose it often.  I will be wheeling primarily on muddy off camber, trails with ruts, and roots all over bouncing around, under loads of throttle.  Have you ever lost the inner bead, and could you see it as being a problem?
KYOTA [OP]
  • Wreckin Ball '09
Re: Beadlocks
« Reply #66 on: Jan 28, 2006, 11:38:08 AM »
never had a problem
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
Re: Beadlocks
« Reply #67 on: Jan 28, 2006, 12:01:48 PM »
Good to know! :thumbs:
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: Beadlocks
« Reply #68 on: Jan 28, 2006, 09:03:16 PM »
Well, I'm kinda bummed reading some posts about not being able to put weld on beadlocks on a 2.5 inch backspaced wheel.  I haven't tried to mount a tire on the one wheel that I have that is beadlocked but I'm guesing it's a pain.  Also, my wheels are 15x10 so they aren't the best size wheel-wise for some of the tires out there.
Does anybody have any experence mounting tires on a weld-on beadlock 2.5 inch backspaced wheel?
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
KYOTA [OP]
  • Wreckin Ball '09
Re: Beadlocks
« Reply #69 on: Jan 28, 2006, 10:15:35 PM »
you CAN do it,the thing is a 2.5 BS wheel is actually a reversed center to get the small backspace, which when reversed now puts the safety bead on the outside of the wheel. So putting beadlocks on a reversed wheel is pointless because then you would be having problems loosing inner beads. just use standard BS wheels, lock them, use spacers if need be and dont look back.
FatAzzRunner
  • Turtle Points: -191
  • Male Posts: 448
  • Member since Jul '02
  • Kansas, Flexin on cowpatties
Re: Beadlocks
« Reply #70 on: Jan 28, 2006, 11:11:43 PM »
I'm runnin into the same dang problem right now man.  I am wanting to do a DIY kit and I also have the 2.5 backspaced wheels and now I have an ad out trying to get someone to trade me 2.5" backspaced black rockcrawlers for 3" or less so I can do my DIY kit.  I was peeest off too as I was just getting ready to order my kit to lock up my wheels.
 :maddest:
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
KYOTA [OP]
  • Wreckin Ball '09
Re: Beadlocks
« Reply #71 on: Jan 29, 2006, 10:42:40 AM »
I know its still money out for new wheels but I only paid  like $38 ea from Summit. US Wheel style 84 15x8  :twocents:
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Beadlocks
« Reply #72 on: Jan 29, 2006, 12:22:29 PM »
Cool, thanks for the heads up on why they won't be good to beadlock.  Makes sense now  :beerchug:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
FatAzzRunner
  • Male Posts: 448
Re: Beadlocks
« Reply #73 on: Jan 29, 2006, 12:50:54 PM »
KYOTA,  maybe you know but...................what backspacing do they STOP reversing the center???  I want as much BS as possible as my current setup is  2.5" BS wheels with 2" spacers.  I run like a total of .5" of BS on my axles.  That is the setup I LOVE  :love:  and really dont want to lose that but understand I would have to with my current wheels.
KYOTA [OP]
  • Wreckin Ball '09
Re: Beadlocks
« Reply #74 on: Jan 29, 2006, 04:31:45 PM »
not real sure where the cut off is before the wheel is reversed, depends on each manufacturer I suppose. Seabass has a thread on pirate aboute the wheels he got from Summit, do a little nosin around over there and I bet you find it.  :beer:
KYOTA [OP]
  • Wreckin Ball '09
Re: Beadlocks
« Reply #75 on: Jan 29, 2006, 04:34:05 PM »
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
  • MC20/21 Toybox #002 2.28 = 154:1
    • MTA
Re: Beadlocks
« Reply #76 on: Feb 14, 2007, 07:54:58 AM »
Weld on the beadlocks and screw the inners with Inchworm screws.
el picas82
  • Male Posts: 71
  • Member since Oct '09
  • i want to get out ther
Re: Beadlocks
« Reply #77 on: Oct 11, 2009, 09:43:59 AM »
y do the rear leafs stick out so much
83 217000 22R :hammer:
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
  • Member since Sep '05
  • Do You Know A Sweeney Bro?
Re: Beadlocks
« Reply #78 on: Oct 11, 2009, 11:31:56 AM »
y do you newbs dig up such old threads? :greengrin:   its probly because he is running 63" chevy leafs
97 4runner Limited
COToy91
  • Turtle Points: -21
  • Male Posts: 1,241
  • Member since May '07
  • Rollin on 37's
Re: Beadlocks
« Reply #79 on: Oct 11, 2009, 01:35:09 PM »
was, it is linked with coilovers now
Last post Oct 08, 2004, 07:49:24 PM
by UNBREAKABLE
Last post Jan 29, 2005, 09:52:28 PM
by ezthere
Last post Oct 02, 2005, 02:35:46 PM
by toybuilt
Last post Nov 11, 2005, 07:12:06 PM
by KYOTA
Last post Sep 14, 2010, 12:18:30 AM
by loudasstoyota
