I need help figuring out where these vacuum lines go to
Started by mudmaster, June 20, 2005, 04:00:44 PM
mudmaster
Engine is a 84 22RE going into a 80
Time to go wheelin!
mudmaster
Time to go wheelin!
mudmaster
Is this for the cruise control?
Time to go wheelin!
Toyminator
1st pic: Goes to the the top of the charcoal canister.
2nd pic: I THINK that one goes to the BVSV for the EGR modulator.
3rd pic: Dashpot. Keeps the throttle from snapping shut too quickly. Has nothing to do with cruise control.
Marlin
Great job Toyminator :thumbs:
Pic 3 is missing a foam breather on the end of the brown vacume bleed valve.
mudmaster
Time to go wheelin!
