FJ40 - Knuckle Dimensions
Started by Mr. Pink, June 20, 2005, 07:58:36 AM
Mr. Pink
All,
I've a TOYOTA BANDEIRANTE here in Brazil and I'm about to convert it to SOA.
I don't know if somebody here knows this model - BANDEIRANTE - but it looks like the american TOYOTA LAND CRUISER - FJ40.
The problem is: I'm about to buy the "Billet High Steer Crossover Arms - 4 Bolt", but I need to confirm the dimensions. Have sure if the both LAND CRUISER FJ-40 and BANDEIRANTE had the same Knuckle (just the steering arms installation dimensions like bolts distance and thickness and bearing "holder" diameter)
Some one can help me!?!?
Thanks,
André Cestari
PS.: For the curious, the brazilian LAND CRUISER FJ-40 <http://www.toyoteiros.com.br/index.php?set_albumName=album48&id=rodrigo_diniz_074&option=com_gallery&Itemid=40&include=view_photo.php>
Marlin
As long as the 4 studs on the top of the kunckle are the 12x1.25mm thread size, the arms will fit.
Marlin
