Wheel spacers
Started by GMAN, June 13, 2005, 02:53:47 PM
GMAN
I have a 2003 Tacoma Double Cab.  I am thinking about using 1.5" wheel spacers to widen the stance and reduce the roll-over possibility.  What are some things that I should be aware of I do this?
KYOTA
Spacers get a bad rep for coming loose but if you keep them torqued properly at regular intervals theres nothing wrong with them. I run 1"er's all the way around my 83, check them regularly and have never found one to be out of torque. You can use Loctite (blue) also if you want.
MiniSimp
I've got the 1.5", use blue locktite, and torque before every run. No problems yet.
mr4x42u
I don't have them on my Yota but did have them on my Sammy loctited them on, they never came loose.
BCB
I have them on my tundra and dont have problems and have them on my 94 toy and dont have any problems just check the torque after a little while and youll be good
