Rear Axle Bearings
Started by snorklehead, January 21, 2003, 01:05:15 AM
snorklehead
Is there a trick or tool (other than a shop press) to use that makes it easier to replace rear axle bearings on a 92 pickup? I had a friend do it and grenade the old bearing race cause he was using it as a press.  :smack:  He about killed himself and everyone around him. I was going to take the axles and have someone do it for me if it wasn't worth the hassle of doing it myself. Thanks. Just trying to save some $ and learn at the same time.
The beatings will continue till morale improves
Ruari
#1
I usually take my axle shaft/drum assembly to my local shop.  It costs me $120.00 out the door.  That includes the new factory toyota bearing and the labor to remove the old and install the new.
Ruari Legg
'84 X-TRA cab, 5.29 Front F-J80 high pinion e-locker/5.29 rear Tacoma e-locker, R.O.R.E. e-locker skid plates, MC dual t-case #480, MC 4.70 gears #1755, Budbuilt crossmember, MC crossover steering, Howe hydro-assist steering, Alcan springs with Orbit Eyes, FRORF full floater, TRD cam, LC Engineering adjustable cam gear, distributer, solid steel engine mounts, longfields, 35"x13.5 BFG Krawlers.
hawaii500_1999
#2
i buy my bearings at applied power(king bearing)  or some other bearing place and the keeper ring at toyota and then have it all pressed apart and together for me.
sometimes i will take the bearing sleeve thing off with a grinder first to save time.  that is the cheapest way i have found to do it.
bearings are usually about half the price at a bearing place.
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
snorklehead
#3
:bowdown:
Thanks for the info. Thats what I figured. Easier with less hassle to take the axles to someone and have em do it for ya. I have access to a shop press so I figured I would ask. But in the end PRICE<HASSLE...
krawlr
#4
These work somewhat like the Toy "SST's":
After you grind the lock ring the puller bolts on and it uses a "bolt type" puller on top, no press needed. Second tool drives the bearing and lock ring on with a hammer. Made from pipe, plate, a fitting and some bolts from the junk drawer.
27-AT, some other adapter, flipped D300, twin sticks on cables.
[shamelessplug] www.krawlr.com [/shamelessplug]
Don
snorklehead
#5
 :idea: I think I have that stuff in my garage sitting around. Thanks for the pics.
cruzila
#6
I was at Marlins Shop recently and he was doing an axle for a customer. It was recently done by someone else and they used a blowtorch to get the race off :~~: :~~: :~~: :~~:  there was a big hole in the axle from the cutter tip. This is probably not the way to do it :smack: :smack: :smack: :smack:
  :stopit::~~: :~~: :~~:
krawlr
#7
Some people use the blue wrench just a little too much. :headshake:
Don
Paul_Elbisser
#8
I made a gig from an old axle housing. Cut out a step where the pumpkin goes. And cut it in half so 2" or so of the axle comes out the end.This can be used in a press. But I have also used 2 Highlift jacks on a trailride just to see if I could.
Sorry no pics
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
snorklehead
#9
Hey Krawlr, Do you have any more pics of the puller? Do you use some sort of cap piece that pushes on the shaft as you wrench it down? Guess I don't see what to use on the top piece to pull the bearing off the axle.  :dunno:
Yeah i don't think ill be using a torch on this...unless I want to replace the whole thing.  :thud:
krawlr
#10
Paul's right an axle tube works great too.
This should help:
Don
#11
Nice :up:
snorklehead
#12
Dude that makes me happy.. Being able to do the bearings without a press in my own garage. Thanks for the pics.
 :beer:
krawlr
#13
I have a press too but it's a pain to get to. :oops:
Don
