33 on ifs
Started by crawlerdan, June 04, 2005, 10:53:17 PM
crawlerdan
anybody got 33s on a stock, nonlifted toy ifs? i do, but everybody told me it couldnt be done, ive got no rub and stock rims? just wonderin if anybody else tried it :psss:
mudaddict
i had it on my runner for a while!!! i had a lil rub when i turned but that was it nohitng to major!
I work At
All Pro Off Road
Duffil
theres a couple on here...
seanc
i know this doesn't sound right, but the customer is always right (high school kid with no money) said just weld me up f/r with a 3" BL :reg:  ok whatever and believe it or not the truck goes like crazy! yes the clutch does stink and it's not as fast as most. but on the cheap it works fine, and it has 35" boggers. no CV's have gone yet, and he does everything from rocks, trails, mud and everything in between.
You win some, you lose some.
crawlerdan
 :chew: THAT SOUNDS LIKE ME IN HIGH SCHOOL, I DID 3 CLUTCHES IN THE TRUCK IN TWO YEARS, I GOT PRETTY GOOD AT IT!!! :slap:
robinhood4x4
I've got 33x10.5 bfg muds on a 1" tbar cranked front end.  I trimmed a little bit and I have no rubbing.
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
crawlerdan
mine are 33x9.5 with no trimming or lifting ala torsion bar :beerchug:
mudaddict
i do no torsion or anyhitng and had 33x12.5 muds on mine i would only rub when craked all the way 1 direction or the other but i did fine on all the trails and rocks very minimal rubbing. i have a 92 runner.
I work At
All Pro Off Road
PandaCrawler
i did 36" tires that were measured at 37" on an IFS turbo runner.. It was an old friend of mine..With stock IFS.. They of coursed rubed so i knocked the fire wall back and cranked the t-bars after i had time.
crawlerdan
right on man :_order:  :_order:  :_order:  :_order:  :_order:
I ran 33's on my 4Runner never rubbed on the front (no articulation), rears rubbed a little though.
Justin
I was running 34 ltb's on stock ifs. Big hammer to the firewall and a saw saw to the fenders
Didn't even have to crank the torsion bars.
crawlerdan
ltbs are cool, i like um :burnout:
tj40ounce
35" MTR's on 2" bs wheels, cranked torsion bars, bfh to the firewall, sawzall...  Only temp until I sas'd it.  Had to adjust the steering stops all the way as well.
www.lucky13offroad.com
www.realsteel.com
91 super yoda
33x12.50 thornbirds, which is more like a 14.50, rubbed at full lock and full compression. rears never rubbed, broke only 1 cv
