3rz to R151 info needed
Started by The_Blue_Coyote, June 03, 2005, 08:48:24 AM
The_Blue_Coyote
Is there a bellhousing that will adapt a 2rz / 3rz to a R151?
I do know the 3rz will bellhousing will bolt to a W56, but need one for the R series.
Does the 5mge or 7mge BH fit the 3rz?
GOT LEAFS ?
www.bluecoyoteracing.com
84 Totota 4x4 class 7S  #797
brainlessfool
I think you need the 22RTE bellhouing
Marlin
Sorry, I am not aware of any known bell to bolt the large 9 bolt R trans to the 2, or 3rz engine :sad2:
mr4x42u
there is an adapter that was due out from I think advanced,,I ask the same question a year ago,,and some one posted the link..I might have it,,or mabe a search would bring it up...let me dig around my links..
The_Blue_Coyote
Thanks.
So far I have talked to Advanced, Marks, couple of vendor in OZ, and nothing is avaialble.
Looks like my friend will have to go to a 5vzfe or ditch the R151.
GOT LEAFS ?
mr4x42u
I'm still looking,,but I know i saw a adapter for it..
