I had a Toyota tcase output modified to 32 spline and turned into an input by OTT for mating a stock Toyota front reduction box to an Atlas.....I was going to send it out for cryoing on Monday, but just ran a file across the "new" 32 spline section of the shaft and it's not hardened......
I'm thinking of having it treated back to the stock hardness before cryoing it, but don't know what the Rockwell number (assuming it's a C scale) is for the stock one.
Does anyone know a "general" range of RC for trans/tcase inputs/outputs? (I'm trying to track down the specific number now, but doubt I'll find it).
Do I need to do anything else to the shaft?......does it need to be normalized first, then heat treated and if so, does it need to be induction hardened, case hardened or what (and to what depth)?
What about buying a used Toyota mainshaft (what my new input is made from) and having it tested for either Brinell or Rockwell to determine the factory hardness and then use it as the coupon for the subsequent heat treat on the new input?
Thanks in advance for any help.
Sean
