Aluminum Lift Block Question
Started by blackdiamond, May 31, 2005, 03:38:51 PM
blackdiamond
I read on another thread that aluminum lift blocks split under load?  Is this a common problem?  Does this apply to solid aluminum blocks?
I have 1.5" solid aluminum blocks ready to be installed on my truck.   :help:
seanc
just get steel ones, cheap insurance
You win some, you lose some.
notajeep
I have broke a set in moab this year and I have a friend that broke a set too.  But they were both the hollow autozone style.  I would think that solid ones would be just fine.  :thumbs:
blackdiamond
I could understand the local autoparts style blocks having problems due to a cheap design.  I know that steel wheels bend and aluminum wheel crack, so I would expect that the same would apply to blocks given enough of an impact load but I doubt that a solid lift block would cause a problem.
Waiting for more opinions.
oddball
I try to stay away from blocks but I think a solid block would be fine, the hollow autozone/pepboys blocks are just for showboaters and not designed for real "offroad use"
Anthony
Blocks and spring wrap go hand in hand.
BirdDog
I called A.O.R about 10 days ago to order their 1' aluminum pucks and they were out. So I went to a local metal shop and bought a bar of 6061 T6 Aluminum and had my own made. I pulled out a set of hollow plastic 3" pucks from 4/w Parts Wholesalers that I have wheeled on for 8 years with no problem.
When I wheel I go Beverly Hillbilly  Style. 4runner loaded to the max. Cargo thing on top loaded to the max. And a trailer fully loaded . So I dont think the aluminum ones will be any problem.
What grade of aluminum pucks do you have ?
shad
#7
Try Roger Brown http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
He sells lift blocks and angle shims for yota's even tapered billet aluminium lift blocks.
86 Toyota 4 runner
My cardomain page
blackdiamond
I got mine from Roger Brown.  I'm not positive if mine are billet or not, but I would guess that they are.  :sneeze:
BirdDog
Sorry Blackdiamond I guess I need to slow down and read . Not body lift, lift blocks.
:_oops:  :slap:
mr4x42u
If you have the solid blocks from rodger brown then ease you rworries..however do keep those u-bolts tight..If you wanted to be way slick about it have a shop weld on a u-bolt keeper plate..that way they can't spit out..
blackdiamond
Quote from: birddog on June 01, 2005, 10:29:24 PM
:_oops: :slap:
All is forgiven
blackdiamond
Quote from: mr4x42u on June 02, 2005, 05:58:46 AM
Roger Brown assured me that I could set a 747 on the blocks if I could get it to balance.  I guess this means that my question is answered and nobody even tried to hijack the thread.
What shall be talk about now?
bjwest
best for me 3in square stock welded to perch and pined to springs
