CHEVY CS 130 ALT.
Started by Jase, May 31, 2005, 03:17:19 PM
Jase
I'm wondering if anyone has wired up a cs 130 alt. to their Toyota??  My toy is an 85 with  the 3 wires running to it along with the 10g. wire to the battery.  The Chevy alt. has the large battery post along with PLFS terminals.  Ideas???  :dunno:
shad
I did one on my 93 toyota 4 runner
http://www.cardomain.com/profile/934rnr
on page 7
Here's the pin out's I had with my old alternator it maybe similar.
The bottom sensor wire as you can see is connected right to the output to the battery the other two the red/white wire is the ignition and that is hooked to the red wire on the toyota alternator harness. The other brown wire on top of the CS130 alternator is the alternator light/voltmeter and that is hooked to the yellow wire on the toyota alternator harness.
86 Toyota 4 runner
My cardomain page
Jase
So the sensor wire from the alt runs right to the battery output then to the battery...correct?  One more question, do your stock dash lights operate as normal?  Mine seem to be charging but wont operate the dash lights properly, but if I install the toy alt everything works fine (but I havent tried your setup yet).
shad
Everything worked fine on mine. I think you can use the sensor wire on your stock harness I decied to simplify it by just running it to the battery wire..
86 Toyota 4 runner
My cardomain page
Jase
Good to go, thanks.  :biggthumpup:
notajeep
do you have any type of part number for that alternator??  The parts places don't know what I am talking about with the cs130 number.  :dunno:
Jase
http://www.alternatorparts.com/cs130_sbpage6.htm    See if this link works, mine was on and 87 chevy astro van with the 4.3 TBI. Hope that helps.
notajeep
Thanks!  :thumbs:  that helps a ton just with the chevy astro van.  :yesnod:
BUBBA
I was wondering how you mounted it?Does it mount in the stock alt. location?
My budget beater
Jase
Yeah, the stock location, it has no problem missing the hood even without a body lift.  (it sits on top/drivers side)
BUBBA
What kind of engine you runnin,cause on the top drivers side of a toy sits the power steering pump
My budget beater
Jase
