Tonka photographs!
Started by 6.72:1, May 26, 2005, 03:58:05 PM
6.72:1
Enjoy!
-Pete Kupfer
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
6.72:1
I thought I would post a few photographs to keep you guys (and gals) updated with the Tonka. I recently grenaded a birfield, but I am currently repairing that. I wonder what could have made that birfield explode like it did? lol. Have a good one!
Your fellow toyotian,
Pete Kupfer
[email protected]
MiniSimp
Quote from: bigtonka on May 26, 2005, 04:02:53 PMI wonder what could have made that birfield explode like it did?
Couldn't have been cause you're running 40's.....no way.... :greengrin:
4DEES
sweet a$$ pics, much props on the rig too. ROCK THOSE 40'S MANG!!!!
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
b_ripper8
There is no way those are 40's.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
MiniSimp
40x17's Id guarantee it.
b_ripper8
Holy crap, I stand corrected.  :headshake:
I think the illusion is that it looks bigger than it really is
b_ripper8
that's what I meant by "holy crap"  :yupyup:
CTENG in KS
You could write a how to guide to rig posing...  :greengrin:
Skinny_Pedal
please o please cut the front fenders :crossed: . then continue to please us with the poserauty pics :biggthumpup:
Im an OG
6.72:1
I was thinking about trimming the fenders, but I don't know how it would look. Should I trim it right below the headlight? I see quite a few fenders trimmed there, but I am not sure how it would look on my truck. I am a photographer, so that's where some of the posing comes from.
[email protected]
4DEES
that rig looks bad A$$ the way it is,looks real good man.props.
Quote from: bigtonka on May 27, 2005, 01:43:10 PM
Just play around with Photoshop and see whatcha like :idea:
6.72:1
I have put alot of work into it, so thank you.
[email protected]
freds40
pull off the air dam below the bumper and @ least cut the fenders even with that.  :thumbs:
"between projects"
Skinny_Pedal
leave about a .25"-.5" left under the headlight. then you can decide if you want it flush or not. i just think 1st gens look goofy with the front fascia under there, even stock and 2wd's. it doesnt work for me is all
Im an OG
But possibly if the stock bumper is used then it fits?
6.72:1
I will see what I can come up with. What should I use to get a clean , straight cut? If I can't do it, how much (approximately) would a body shop charge to trim me up about .25" below the headlight?
[email protected]
freds40
I'd use either a air body saw or a 4.5" angle grinder with a cut-off wheel. With the saw, throw some masking tape over the whole lower portion of fender, then with a pencil, draw where you want to cut. The air saw is very controlled and the masking tape will keep from marring the paint. With the angle grinder (what I used when I still had sheet metal) the diameter of the wheel helps to make nice clean straight lines but it can wrinkle the paint from heat if you are not careful.
"between projects"
