Someone please confirm ...
Started by RCRunner, May 17, 2005, 05:10:51 PM
RCRunner
Okay ... I did search and found some information but not the answer I was looking for ... Can a rear 88 4cyl third member fit into a 88 V6 rear axle housing? If so, any issues? If not ... I'll have a 4cyl. 3rd member, 5.29 gears (unknown brand), welded carrier (spooled) for sale soon ...
BTW ... this is for a 88 V6 4Runner
BLUCRUZ
Quote from: RCRunner on May 17, 2005, 05:10:51 PM
:yesnod:
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
Yes it can. All 4WD 4cyl NA and Turbo, and 3.0 V6 8" differentials are interchangeable between all 8" 79-95, Including 96-2005 TRD rear ends (e-locking 8").
The best setup is to run a V6 diff. You could even run a 1995 V6 diff in a 1979 rear end. Very strong compared to the 4cyl diff.
Duffil
10-4...he's right!  why are you goning to put a 4cyl 3rd in a v6 housing behind a v6???  :headscratch:
Quote from: BigMike on May 17, 2005, 05:30:55 PM
I was just thinking about this, I am right about it fitting, but I believe two of the studs for the e-locking diff need to be repositioned for the bolt pattern of a non e-locker.
You have to clearance the housing for the shift fork on the motor assembly too.  ;)
