2.7 supercharged taco engine
Started by Paul_Elbisser, October 02, 2002, 07:04:08 AM
Paul_Elbisser
Anyone have specs on this motor? ow about what trans can bolt to it? Can I hook a W sieries to it without adapters?
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
Cracker
#1
Paul,
The 4cyl (2.7) Tacos use the W59 tranny, so I would be about 90% sure that, yes, a W56 would bolt up to the Taco bellhousing no problem.
Art
99 Taco
80 Hilux - 20/22R Hybrid, Dual Mikuni's, R151 trans, Budbuilt X-member
74 FJ40 "The Project"
#2
No and Yes, the RZ engine has a different bolt pattern than the R engine, but since the Taco is using a W-series trans, anything behind the bellhousing can be W-xx. So you could place a W56 behind a 3RZ-FE 4cyl Taco as long as you run the W59 Taco bellhousing. :up:
#3
QuoteAnyone have specs on this motor?
2WD Engine:
2RZ-FE  2.4L  142 HP@5000, 160 TQ@4000
4WD Engine:
3RZ-FE 2693cc (2.7L)  150 HP@4800,  177 TQ@4000
Both engines are 9.5:1 compression, 4 valves / cylinder, DOHC.
alfio
Quote from: BigMike on February 13, 2003, 06:50:29 PM
2WD Engine:
4WD Engine:
this is an old post but i'm curious about this info. what makes for the 8 HP/17TQ power difference?
alfio
Like the saying goes...Theres no subsitute for bubic inches.
WT
brainlessfool
hawaii500_1999
displacement is where the power comes from.
also the original post was asking about the superchargered vertion.  TRD sells a bolt on blower for the Tacos that runs about $3,000 and it should be ran with a header, and big bore throttle body.
the motor is supposed to put out 200 hp with the blower.  i looked into it for my DD 2002 taco but just couldn't justify the price.  the factory warrenty would still be usable as well, because it is a "toyota modification." with "toyota" parts.
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
Quote from: WHITE_TRASH on April 20, 2004, 03:16:25 PM
WT
There's no replacement for displacement!!
88runner
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
Right, that's from Pat and Mattis' webpage at http://www.geocities.com/MotorCity/Pit/9975/tm_index.html
That's where I got my figures above from. Lots of good info. Also If you are looking to learn about smaller 4 cyl engines and some indept tech and talk, check out Billzilla's webpage at: http://www.billzilla.org/carindex.htm Check out some articles in his Car Tech Section.
