The Capacity/Size/Weight/Length Thread
Started by BigMike, May 07, 2005, 10:52:43 AM
John Doe
Quote from: tanabuse on January 04, 2011, 05:51:09 PM
i belive there 18 mm
My question was about the size socket needed for the bolt head and nut, not the thickness of the Bolt.
I have since found the bolt and nut to 27mm
22mm socket for the U bolt bolts
19mm socket for the castle nuts on TRE's
14mm for leaf spring centering pin
jrock
I read this recently, I can't remember where and I can not confirm it, but here it is.
22re dressed weighs 340lbs
1uzfe dressed weighs 390lbs
3vzfe dressed weighs more.
Cuz I couldn't find it,
18mm shackle bolts use a 1 1/16" socket.
tanabuse
so can an 86 4runner body bolt onto an 85 short bed 4x4 solid axel frame
frome
Quote from: MiniSimp on May 09, 2005, 06:31:57 PM
1985 Truck(LWB/SWB)/4Runner Chassis Dimensions
Turning
Over after
Years
Of
Trail
Aabuse
John Doe
the front 2 sets Should line up fine, but the body mounts in the bed area will probably be off a little. Its nothing that a little grinding and welding cant fix.
I cant find it.... whats the fluid capacity of a 3VZ-E Power Steering System?
Outsane
Quote from: THK on February 08, 2011, 03:18:25 PM
Anyone?
GreenYoterKrawler
Inner Axle Lengths please?
Hilux, Short Side:
Hilux/FJ60, Long Side:
FJ40/FJ60, Short Side:
FJ40, Long Side:
& Whats the Inside diameter of a toyota solid front axle?
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
TURBO
Quote from: Outsane on February 22, 2011, 01:53:57 PM
Gas Tank Capacities?
my owner's manual for my 89 (1st gen) 4Runner says the gas tank holds 17.7 gal
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
TURBO
#129
Quote from: GreenYoterKrawler on February 28, 2011, 07:20:48 AM
Hilux, Short Side:
FJ40, Long Side:
i'll get back to you
mini truck long side... axle only...
               31.5in
mini truck short side... axle only...
             15 and 5/16 in
I AM :screwy:!!!
TURBO
I AM :screwy:!!!
TURBO
I AM :screwy:!!!
Quote from: TURBO on September 14, 2011, 06:52:12 PM
That must be unique for a V6. Our 1987 4cyl 4Runner only took about 12 gals per fillup (so it probably had a 14 gal tank). An 18 gal tank sounds much more like a long bed tank, not a short bed tank as would be the case in the 4Runner. But hey, it's in your owners manual so that has to be right :idea:
TURBO
yeah weird huh? i've been sooo low on gas once that i put 17.8 some gallons in... the truck was cutting out and i barely made it to the pump... it was awesome
just out of curiosity, i found my owner's manual, and i stand corected... it's 17.2 gallons (65 liters)
I AM :screwy:!!!
TURBO
other facts from the 1989 Toyota 4RUNNER Owner's manual
DIMENSIONS AND WEIGHT
                    in.      (mm)
overall length   174.8  (4440)
overall width     66.5  (1690)
overall height    66.1  (1680)
wheelbase       103.3  (2625)
front tread        56.3  (1430)
rear tread         55.5  (1410)
cargo weight     lbs.    (kg)
rating              300    140  *vehicles with rear seats sold outside Canada
                     440    200  *vehicles with rear seats sold in Canada
                     700    320  *vehicles without rear seats
ENGINE
displacement, cu.in (cc)
  22R-EC 144.4 (2366)
  3VZ-E  180.5 (2958)
valve clearance, in (mm)
22r-ec engine (engine hot)
  intake               0.008 (0.20)
  exhaust            0.012  (0.30)
3VZ-E engine (engine cold)
  intake               0.007-0.011 (0.18-0.28 )
  exhaust            0.009-0.013 (0.22-0.32 )
Spark plug gap: 0.031in (0.8mm)
ENGINE LUBRICATION
Oil capacity, qt. (liter)
22R-EC engine
  Dry fill                                   5.1  (4.8 )
  Drain and refill with filter           4.5  (4.3 )
  Drain and refill without filter       4.0  (3.8 )
3VZ-E engine
  Dry fill                                   5.6  (5.3 )
  Drain and refill with filter           4.8  (4.5 )
  Drain and refill without filter       4.4  (4.2 )
MANUAL TRANSMISSION
3.2 (3.0)
Oil type: multipurpose gear oil API GL-4 or GL-5
Recommended oil viscosity:
22R-EC engine
 SAE 75W-90 or 80W-90
3VZ-E engine
 SAE 75W-90
AUTOMATIC TRANSMISSION
Fluid capacity, qt. (liter)
Dry fill                      10.9 (10.3)
Drain and refill           Up to 4.8 (4.5)
Fluid type: automatic transmission fluid DEXRON-II
TRANSFER
(vehicles with manual transmissions)
22R-EC engine               1.7 (1.6)
3VZ-E engine                1.2 (1.1)
Oil type:    Multipurpose gear oil API GL-4 or GL-5
22R-EC engine
3VZ-E engine
 SAE 75W-90
TRANSFER
(vehicles with automatic transmissions)
Dry fill                   1.2  (1.1 )
Drain and refill        0.8  (0.8 )
DIFFERENTIAL
front                      1.7 (1.6 )
rear                       2.3 (2.2 )
Oil type: hypoid gear oil API GL-5
Above 0 degrees F (-18 degrees C)       SAE90
Below 0 degrees F (-18 degrees C)       SAE 80W or 80W-90
COOLING SYSTEM
Total capacity, qt. (liter)
22R-EC engine
  with manual trans.      8.9 (8.4)
  with auto trans.         9.6 (9.1)
3VZ-E engine
  with manual trans.     11.1 (10.5)
  with auto trans.        10.9 (10.3)
coolant type: Ethylene-glycol coolant (do not use alcohol type.)
TIRES AND WHEELS
Tire size:      225/75R15
Recommended cold tire inflation pressure:
 Front          26 psi  (180 kPa)
 Rear           29 psi  (200 kPa)
 for sustained high speeds above 75 mph (120 km/h), in countries where such speeds are permitted by law, add 3 psi (0.2kg/cm2,20 kPa), but never exceed the maximum cold tire pressure molded on the tire sidewall
Wheel size:
Steel wheels                15 x 6JJ
                                 6-JJ x 15
Aluminum wheels        15 x 7JJ
                                7-JJ x 15
Wheel nut torque, 76 ft-lb (103 N.m)
I AM :screwy:!!!
TURBO
You can buy the original Factory Service Manual (FSM) at:
    Toyota Material Distribution Center
    750 West Victoria St
    Rancho Dominguez/Compton, CA 90220-5538 USA
    1-800-622-2033
    (outside CA)(M-F: 7-5 PST)
    1-800-443-7656 (inside CA)
    1-310-818-4630 (in or outside CA)
or for 2004 and older go to http://www.helminc.com
I AM :screwy:!!!
TURBO
#136
found this on the Yota Tech Forum
http://www.yotatech.com/f115/fsm-nearly-all-years-factory-service-manual-156129/
   4RUNNER
   1985 Toyota 4-Runner & pickup Factory Service Manual:
   http://www.functionalfab.com/resourc...%204runner.pdf
   http://www.ncttora.com/fsm/1985/1985FSM.pdf
   http://www.muchadoproductions.com/in...tatruckfsm.pdf
   http://www.truckporn.com/tech/FSM/Toyota/1985fsm.zip
   http://s3.uploadline.com/d/4831811/1...85/1985fsm.zip
   http://www.lukemiller.org/toys
   http://www.lukemiller.org/toys/1985_...nsions_FSM.pdf
   http://www.lukemiller.org/toys/1985_...r_case_FSM.pdf
   http://www.lukemiller.org/toys/1985_...t_axle_FSM.pdf
   http://www.subliminaltrips.com/1985toyotatruckfsm.pdf
   1987 Toyota 4-Runner Factory Service Manual:
   http://rapidshare.com/files/34005580....RUS.part1.rar
   http://rapidshare.com/files/34006565....RUS.part2.rar
   1988 Toyota 4-Runner & pickup Factory Service Manual:
   http://granolaboy.net/temp/toyota_tr...4runner_88.pdf
   1990 Toyota 4-Runner Factory Service Manual:
   http://rapidshare.com/files/34006966...0.1995.SIL.rar
   1993 Toyota Pickup Service Manual:
   http://www.ncttora.com/fsm/1993/index.html
   http://personal.utulsa.edu/~nathan-buchanan/93fsm
   http://www.ncttora.com/fsm/1993/1993.zip
   http://www.snjschmidt.com/wiring
   1995 Toyota 4-Runner Factory Service Manual:
   http://www.the-roo.com/4runner (3VZE engine, 3 liter, V6)
   1996 Toyota 4-Runner Factory Service Manual:
   http://rapidshare.com/files/34004224...6.2002.SIL.rar
   1998 Toyota 4-Runner Factory Service Manual:
   2002 Toyota 4-Runner Factory Service Manual:
   http://rapidshare.com/files/34007037...2.Audio.SM.rar
   2006 Toyota 4-Runner Factory Service Manual:
   http://rapidshare.com/files/34007101...r.2006.SIL.rar
   TACOMA
   1996 Toyota Tacoma Factory Service Manual (2)(3)RZ-FE 5VZ-FE:
   http://www.ncttora.com/fsm/1996/96_repair.zip
   http://www.ncttora.com/fsm/1996/images/index.jpg
   1998-2000 Toyota Tacoma Factory Service Manual 5ZE-FE:
   http://www.ncttora.com/fsm/2000/index.html
   http://www.ncttora.com/fsm/2000/2000_FSM.zip
   2003 (years: 2001-2004) Toyota Tacoma Factory Service Manual (2)(3)RZ-FE 5VZ-FE:
   http://www.deserted1.com/FSM
   http://www.ncttora.com/fsm/2003/index.html
   http://www.ncttora.com/fsm/2003/2003_FSM.zip
   2005-2006 Toyota Tacoma Factory Service Manual
   1GR-FE & 2TR-FE:
   http://www.ncttora.com/fsm/05+/index.html
   http://www.ncttora.com/fsm/05+/05+_FSM.zip
also look here:   http://www.ncttora.com/fsm/
I AM :screwy:!!!
TURBO
#137
did i miss the list of transmission ratios???
i guess if it's on the main page it could be here too
http://www.marlincrawler.com/tech/transmission/transmission-gear-ratio-chart
I AM :screwy:!!!
builttoabuse
Quote from: BigMike on May 08, 2005, 09:04:36 PM
Oh whoops, I think it's 0.8 quarts for a Crawl Box. So about 2.5 for a complete Dual Case.
Am I a dumbass? I put 4
rts in duals and 4 in my w56a? What's correct?
toy obsessed!
Quote from: TURBO on October 10, 2011, 04:38:27 PM
                     in.      (mm)
ENGINE
   22R-EC 144.4 (2366)
   3VZ-E  180.5 (2958)
   intake               0.008 (0.20)
ENGINE LUBRICATION
22R-EC engine
   Dry fill                                   5.1  (4.8 )
3VZ-E engine
   Dry fill                                   5.6  (5.3 )
MANUAL TRANSMISSION
3.2 (3.0)
22R-EC engine
3VZ-E engine
  SAE 75W-90
TRANSFER
22R-EC engine
3VZ-E engine
  SAE 75W-90
TRANSFER
Dry fill                   1.2  (1.1 )
DIFFERENTIAL
front                      1.7 (1.6 )
rear                       2.3 (2.2 )
COOLING SYSTEM
22R-EC engine
3VZ-E engine
TIRES AND WHEELS
Wheel size:
                                  6-JJ x 15
                                 7-JJ x 15
Quote from: socaltoy on January 12, 2013, 11:34:56 PM
im gonna bank on dumbass.... being as you looked at the capacity for an Auto transfer case bro.
Goldrush
Haha!
builttoabuse
Quote from: THK Matt on January 13, 2013, 09:03:57 AM
does your drivetrain even rotate?
no not that dumb to do that I just put in oil till it came out of fill hole and thwy were both dry
toy obsessed!
Then ur good.
Sent from the HO KID network using Tapatalk 2
builttoabuse
Quote from: THK Matt on January 13, 2013, 10:43:06 AM
Then ur good.
8 qrts seems like alot
toy obsessed!
Goldrush
good information for us turbo! thanks alot!
Maddmark1
What about carrier size Or third member and ring in pinon sizes Five lug or six lug?
