The Capacity/Size/Weight/Length Thread
Started by BigMike, May 07, 2005, 10:52:43 AM
This Thread is Featured in our Tech from our Forum Members section!
This is a place to put all common specifications/capacities/sizes/widths/lengths/etc for our beloved Toyota Trucks!!
I'll start it off:
Toyota Front Axle Widths:
55.3" wide, '60-83 FJ40
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners
58.5" wide, '81-87 FJ60
58.5" wide, '86-95 IFS front end
63.5" wide, '91-92 FJ80
63.5" wide, '93-97 FZJ80
65" wide, '93-98 T100 IFS front end
Toyota Rear Axle Widths:
55" wide, '79-85 trucks/4runners
55.1" wide, '60-83 FJ40
57.9" wide, '81-87 FJ60
58.5" wide, '86-95 trucks/4runners
60" wide, '95.5-up Tacomas/4runners
62.2" wide, '91-92 FJ80
63" wide, '93-97 FZJ80
66.75" wide, '93-98 T100 trucks
Some Capacities:
##R Engine Oil: 5 Quarts
#VZ Engine Oil: 5.5-5.75 Quarts
3RZ Engine Oil: 5.5 Quarts
4.0 Toy V6: 6.4 Quarts
4.7 Toy V8: 6.0 Quarts
W56: ~3.0 Quarts
Gear Drive T/Case: 1.5 - 1.7 Quarts
Crawl Box: ~0.8 Quarts
Crawl Box + Gear T/Case: 2.3-2.5 Quarts
Toy Hilux Differential Gear Oil: 2.3 Quarts
Drivetrain Lengths:
Marlin Crawler Transmission Dimension Chart
       by Marlin Czajkowski
Transmission
Length of
Bellhousing
Distance to
Shift Handle
Distance to
T-Case Handle
Total Distance
L45/L50/L52
-19-1/16"20-3/4"
G52/G54 (84-87 22R Carb)
6 3/8”19”23 ½”25 ½”
W56 A, B (85-89 22R EFI)
6 3/8”21 ¼”--25 ½”
W56 C, D, E (89-95 22R EFI)
6 3/8”19 1/8”24 ¼”25 ½”
R150 (88-95 3.0 V6)
6 ¼”21 7/8”--24 7/8”
R151 (86-87 22R Turbo)
6 3/8”19”23 ½”25 5/8”
W59 (96-04 22R, 3RZ Tacoma)
6 7/8”22 ¼”--25 ½”
R150 (96-04 3.4 V6)
7 3/8”23”--26 1/8”
Marlin's personal opinion on Transmission Strength Comparison:
G52 is 0% stronger than a L52.
G54 is 20% stronger than a G52.
W56 is 40% stronger than a G54.
R15# is 100% stronger than a W56.
Transfer Case Lengths:
Gear Drive T/case from front face to rear flange face: 14" (apprx)
Gear Drive T/case from front face to front flange face: 1.75" (apprx)
Marlin Crawler Dual Case Unit: 6.5"
Chain Drive T/case from front face to rear flange face: 12.5"
Chain Drive T/case from front face to front flange face: 3.25"
Engine Data:
Engine....Valves..Displacement..Horsepower....Torque........Bore......Stroke....Compression
18R-GE21968cc135@5800127@440088.5mm808.3:1
20R2218990@4800122@24003.48"3.58.4:1
22R2236696@4800129@28003.62"3.59.0:1
22R-E22366112@4600142@340092899.0:1
22R-TE22366135@4800173@28003.62"3.5"7.5:1 - Boost: 6 psi
2RZ-FE42.4l142@5000160@40009.5:1
3RZ-FE42693150@4800177@400095959.5:1
2TR-FE42693165@4800183@400095959.5:1 with VVTi (2005+)
3VZ-E32958150@4800180@340087.5829:1
5VZ-FE43378190@4800220@360093.5829.6:1
5M-GE22759161@5600169@440083859.2:1
7M-GE42954199@6000188@360083919.2:1
7M-GTE42954232@5600254@320083918.4:1 - Boost: 5 psi
F23878135@3800217@2000891027.5:1
2F24230140@3600218@1800941027.8:1
1GR-FE43956236@5200266@380010.0:1
2UZ-FE44664245@5400315@34009.6:1 2000-2004
2UZ-FE44664271@5400313@34009.6:1 2005+
3UR-FE45663381@5600401@36009410210.2:1
Added 12/31/2012:
Toyota Standard Bolt Torque Specifications as taken from a 1985 FSM
Here is the direct link to the full size image (1581x985 pixels): standard-bolt-torque-specifications.gif
Here is a preview image which links to the full size image:
#1
Wheelbases:
1960-83 Landcruiser FJ40: 90"
1963-67 FJ45 Shortbed Pickup: 95.7"
1963-67 FJ45 Longbed Pickup: 104.3"
1968-79 FJ55: 106.3"
1981-87 FJ60: 107.5"
1988-90 FJ62: 107.5"
1991-92 FJ80: 112.2"
1993-97 FZJ80: 112.2"
1979-83 Shortbed: 103"
1979-83 Longbed: 109"
1984-88 4Runner (-1989) & Shortbed Trucks: 103"
1984-88 Xtracab & Longbed Trucks: 112"
1989-95 Shortbed & 4Runners: 103"
1989-95 Xtracab & Longbeds: 122"
2004 Tundra Double Cab: 140.5"
2005 Tacoma Regular Cab: 109.4"
2005 Tacoma Access Cab: 127.2"
2005 Tacoma Double Cab - Short: 127.2"
2005 Tacoma Double Cab - Long: 140.9"
VIN Chassis Identifiers: (added 8/7/2006)
ModelStyleYearCodeEngine
Hilux 4WD
Std/Long Bed1980 - 1980RN37/4720R
Hilux 4WD
Std Bed1981 - 1983RN3822R
Hilux 4WD
Long Bed1981 - 1983RN4822R
Hilux 4WD
Diesel1984 - 1984LN652L
Hilux 4WD
Turbo Diesel1985 - 1987LN65/662LT
Hilux 4WD
Carb1984 - 1988RN60-6622R
Hilux 4WD
EFI Reg & XCab1985 - 1988RN60-6622R-EC
Hilux 4WD
TrboReg & XCab1986 - 1987RN61/6622R-TEC
Hilux 4WD
V61988 - 1988VZN61/63VZ-E
Hilux 4WD
I4 RegCab1989 - 1995RN101/622R-E
Hilux 4WD
I4 X-Cab1989 - 1995RN11022R-E
Hilux 4WD
V6 RegCab1989 - 1995VN100/53VZ-E
Hilux 4WD
V6 X-Cab1989 - 1995VZN1103VZ-E
4Runner 4WDI4 Carb1984 - 1984RN6022R
4Runner 4WD
I4 Turbo1986 - 1987RN6122RT-EC
4Runner 4WD
I4 EFI1985 - 1989RN60/6122R-EC
4Runner 4WD
I4 SR51990 - 1995RN130/122R-E
4Runner 4WD
I41996 - 2000RZN1853RZ-FE
4Runner 4WD
V6 SR51988 - 1989VZN613VZ-E
4Runner 4WD
V6 SR51990 - 1995VZN13#3VZ-E
4Runner 4WD
V61996 - 2002VZN1855VZ-FE
4Runner 4WD
V6 SR5/LTD2003 - 2007GRN2151GR-FE
4Runner 4WD
V82003 - 2007UZN2152UZ-FE
Tacoma PrerunI4 XtraCab1998 - 2004RZN1963RZ-FE
Tacoma Prerun
I4 4Dr2001 - 2004RZN1963RZ-FE
Tacoma Prerun
I4 RCab2005 - 2007TRN2402TR-FE
Tacoma Prerun
I4 XCab2005 - 2007TRN2452TR-FE
Tacoma Prerun
V6 XtrCab1998 - 2004VZN1955VZ-FE
Tacoma Prerun
V6 4 Dr2001 - 2004VZN1955VZ-FE
Tacoma Prerun
V6 X-Cab2005 - 2007GRN2451GR-FE
Tacoma Prerun
V6 4Dr Short2005 - 2007GRN2451GR-FE
Tacoma Prerun
V6 4Dr Long2005 - 2007GRN2501GR-FE
Tacoma Srunner
V6 X-Cab2001 - 2004VZN1955VZ-FE
Tacoma Xrunner
V6 X-Cab2005 - 2007GRN2251GR-FE
Tacoma 4WD
I4 RegCab1995 - 2004RZN1613RZ-FE
Tacoma 4WD
I4 XtrCab1995 - 2004RZN1713RZ-FE
Tacoma 4WD
I4 RegCab2005 - 2007TRN2602TR-FE
Tacoma 4WD
I4 X-Cab2005 - 2007TRN2652TR-FE
Tacoma 4WD
V6 RegCab1995 - 1997VZN1605VZ-FE
Tacoma 4WD
V6 XtrCab1995 - 2004VZN1705VZ-FE
Tacoma 4WD
V6 4 Dr2001 - 2004VZN1705VZ-FE
Tacoma 4WD
V6 X-Cab2005 - 2007GRN2651GR-FE
T100 4WD
V6 RegCab 1/2T1993 - 1994VCK203VZ-E
T100 4WD
V6 RegCab/XCab1995 - 1998VCK215VZ-FE
Tundra 4WD
V6 RegCab1999 - 2004VCK405VZ-FE
Tundra 4WD
V6 4 Dr1999 - 2004VCK405VZ-FE
Tundra 4WD
V8 RegCab1999 - 2006UCK402UZ-FE
Tundra 4WD
V8 4 Dr1999 - 2006UCK402UZ-FE
Tundra 4WD
V8 4 Dr2004 - 2006UCK412UZ-FE
Hyena
What about dual transfer cases?  whats the oil specs on those?
#3
Quote from: BigMike on May 07, 2005, 10:52:43 AM
Tcase: 1.5 - 1.7 Quarts
Some transmissions have a larger cavity in their tailhousings, so as the transfercase is bolted up behind the trans, a bit more oil is needed to fill the larger cavity.... I believe it's the W's
Hyena
How much more oil is in the back part of the t-case then in the front?  Like in the 4wd section rather then the front box part?  Or does anyone know?
Oh whoops, I think it's 0.8 quarts for a Crawl Box. So about 2.5 for a complete Dual Case.
Hyena
Cool, thanx.  You should make this a sticky!
MiniSimp
Quote from: BigMike on May 08, 2005, 08:21:53 PM
Wheelbases:
1984-88 4Runner (-1989) & Shortbed Trucks: 102.95"
Fixed it for ya Mike
Hyena
I think he was just rounding up.  Cuzz 22r's take 4.9 quarts of oil, not 5, but i guess it doesn't hurt it.
MiniSimp
1985 Truck(LWB/SWB)/4Runner Chassis Dimensions
Snowtoy
Quote from: BigMike on May 07, 2005, 10:52:43 AM#VZ Engine Oil: 5 Quarts ?
I find it takes 5.5-5.75 quarts to fill my 3vze.
Quote from: Snowtoy on May 10, 2005, 01:52:03 PM
Thanks for the correction. I had a question mark on that one, it was a complete guess. Im sure there is other data that is wrong to, so if you see something else, let me know-
Snowtoy
I am not sure if it is all 3.0's take more.  I know mine has always taken more than the book calls for to register on the dip stick on my '90, as well as on my sisters '95.  I am curious if others find it takes more oil as well.
guywithuglyyota
That may be becasue the oil filter absorbs about a pint, maybe a tad more.
Hyena
UNBREAKABLE
somebody has a frame machine or has had to do some "adjusting" on one :yesnod:
That's how I roll
synwars
Quote from: 4LOWx2 on May 11, 2005, 12:43:54 AM
HOLY FRIGGIN' OIL FILTER. That's huge!!! That's like just under the size of filter we use on our huge CAT engines in our transport trucks!!! Or like the high capacity filter that my friend uses for his chev 350. GOSH!
Build up thread:
KEEP IT CLEAN PEOPLE!!! :bat:
guywithuglyyota
Really? I thought a pint wasnt all that much. 1 pint=  16oz about 1/2 a quart.   Hell my filter (amsoil sdf-15) soaks up a quart=2 pints.
MiniSimp
#19
Weight of Round Steel Tubing
Outside Dia. Wall Thickness Weight per Foot
1.25              .049          0.629
1.25              .095          1.172
1.25              .120          1.448
1.5                .049          0.759
1.5                .065          0.996
1.5                .083          1.256
1.5                .095          1.426
1.5                .120          1.769
1.75               .049         0.890
1.75              .065          1.170
1.75              .083          1.478
1.75              .095          1.679
1.75              .120          2.089
2.0                .049         1.021
2.0                .065         1.343
2.0                .083         1.699
2.0                .095         1.933
2.0                .120         2.409
:gap:
MiniSimp
mr4x42u
Quote from: Hyena on May 09, 2005, 06:09:22 PM
If you use the ford 1515 filter it will hold about an even 5 quarts and has more paper for filtration..
UNBREAKABLE
DAMN! 16"X16"   9/16"   Tubing weighs 127 LBS a foot! :yikes:
That's how I roll
awhotrods
BigMike,
Are you sure on your V8 engine specs?
I have a 2004 Tundra V8 and it is rated at 245 hp and 315 lb-ft (rpm?) and the new 2005 v-tech trucks are something like 282 hp and 325 lb-ft per the dealer spec.
:dunno: I got those #s from motortrend I believe.. I'll add the previous year
From Toyota.com
4.0 V6 (2005)
224 HP @ 5200 rpm
282 LB-FT @ 3800 rpm
4.7 V8 (2005)
282 HP @ 5400 rpm
325 LB-FT @ 3400 rpm
And I nearly positive that my 2004 V8 is
240 HP @ 5400 rpm
315 LB-FT @ 3400 rpm
gotrocks
wow i just found this thread and its totally helpful.  keep the stats coming
MiniSimp
Toyota Leaf Springs
                                           Flat length  Front Half   Rear Half   Width   SOA / SUA
80-85 Toyota front                      45"          22.5"        22.5"       2.36"        SOA
80-85 Rancho 3" Toyota front     45.12"       22.56"      22.56"      2.36"        SOA
SkyJacker 5" Toyota front            46"            23"           23"        2.36"       SOA
80-88 Toy rear                           48"           20.5"        27.5"      2.36"        SOA
80-88 4" SkyJacker Rear              49"            21"           28"        2.36"       SOA
80-88 5" SkyJacker Rear              49.5"       21.25"      28.25"      2.36"        SOA
89-95 Toy Rear                          51"          21.5"        29.5"       2.36"        SOA
Source: DRM
