pinion angle issue?
Started by coconut, May 06, 2005, 08:51:40 PM
coconut
i got a 4inch sas kit and a 3 inch body lift on my 91 pickup.. 85 axle w/ a v6 third (should of went with the high pinion third but i gotta run with what i got  :smack: )i know the dual case will help a lot which will be very soon.. what else can i do to get better  pinion angle????
91 std pick up,3.4 swap, R151w/doubled up 4.7 in the rear, twin sticks, FROR x member,Marlins 4"sas w/ a 85 SA, high pinion ARB, 30 spline longs,chevy rear w/ ARB's and sitting on 36 iroks w/ beadlock speciality wheels
b_ripper8
Cut and rotate your knuckles.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
coconut
rotate kuckles and cases and thats it?
b_ripper8
If you rotate your knuckles, your pinion angles will be wherever you want it.
coconut
howmuch would that cost? i live in sac area
b_ripper8
I don't even know if there's a place that will do it for you. Try searching around for instructions on here and Pirate. If you're not handy with a welding machine, you can shim to correct your pinion angle.
coconut
like to do it in house. is there a thread i can read that i can research?\
:crossed:
Have your alognment checked by a local shop.  Many shops will put your rig up on the rack and check what everything is set at for free.  Put shims under your springs to get the castor back in speck and that will help the pinion angle aw well.
coconut
yea i heard the shim thing i dono ??? :dunno: pretty savy welder thats one thing i love to do
coconut
whats the down fall on rotating the knuckles
b_ripper8
Takes time and measuring. After welding your pinion angle is once again set like it was before.
coconut
UNBREAKABLE
Figure out where the angle needs to be. Build a jig to hold your knuckles in the same place, cut them off, reweld and be done
That's how I roll
coconut
is there any threads out there that i can research off of?( pics,etc.)
