Author Topic: Power steering for 1st gen pickup???  (Read 6100 times)
konatoy
  • Turtle Points: -13
  • Male Posts: 30
  • Member since May '04
« on: May 03, 2005, 01:15:39 AM »
i got a 1st gen pickup with a 20R motor, and the push pull steering setup still. But i was wondering if it is nesessary to do a power steering swap, if you build a locked & geared with 35s pickup???? if it is, what do you need to do, or get?? thank you very much
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: Power steering for 1st gen pickup???
« Reply #1 on: May 03, 2005, 06:46:18 AM »
I've got an 85 without PS.  It's a 22R so I just found a guy locally that sold me the PS bracket and crank pulley from a 22RE.  I'm going hy-steer so I've got my IFS powersteering box and pump.  In your case, you will need to find the PS bracket and crank pulley from a 20R and everything should bolt right up.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
« Reply #2 on: May 03, 2005, 06:56:57 AM »
You going to want p/s with a locked and geared rig..I run a detroit and 36 irocks and wish I has hydro assist..so i thats what i'm going to do..stock power steering is still not good enough..
konatoy [OP]
  • Male Posts: 30
« Reply #3 on: May 03, 2005, 01:30:04 PM »
how hard is it to do a hydro assit, if you dont have a PS box, or anything like that, are there any kits, or anything like that????
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: May 06, 2005, 06:59:58 PM »
cant use hydro on the street,
finda 86+ truck an get the  gear box and pump and hoses from it ,   you can use the pump with the early style gear box till you go crossover
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
« Reply #5 on: May 07, 2005, 05:53:38 PM »
hydro assist is fine on the street, full hydro(e.g. no steering box) is sketchy.
if you want to gain power steering and run 35s, you're going to be better off swapping an IFS box and hysteer on.  won't be much more work than just swapping to power steering.
musclesliver
  • Turtle Points: -36
  • Male Posts: 81
  • Member since Aug '05
  • huh??? Where am I???
« Reply #6 on: Sep 07, 2005, 07:24:59 PM »
hysteer with an ifs box
Toyminator
  • Turtle Points: 375
  • Male Posts: 54
  • Member since Aug '04
  • Anchorage, Alaska
    • Alaska Wheeling Forum
« Reply #7 on: Sep 07, 2005, 08:01:15 PM »
I've seen a few 20R's with no provisions for mounting a power steering pump bracket. You may have to drill and tap some holes in the block.
kyle_22r
  • Male Posts: 1,233
  • yellow beast
« Reply #8 on: Sep 08, 2005, 10:22:38 PM »
if it's a stock 20R, it'll have the PS pump and fuel pump mounts('79 had electric fuel pump, 80 had mechanical pump on the head, both are the same style 20R though).  the 20R motors without the fuel pump/front PS hole are the '75-78 models.
Last post Jan 14, 2005, 11:03:44 AM
by fuglytruck
Last post Jan 17, 2005, 12:08:35 AM
by WHITE_TRASH
Last post Mar 06, 2009, 11:47:28 AM
by Thomas P
Last post Aug 11, 2010, 04:20:41 AM
by Rocksurfer
Last post Jan 03, 2011, 12:32:16 PM
by Fisch_Taco
