Stock PS Reservoir Mounting on 79-83?
Started by YOguyDa, April 18, 2005, 09:23:48 PM
YOguyDa
When i got my truck the PS reservoir was zip-tied to something.....So i ended up mounting it off of one of the radiator shroud bolts...In front of the cool air duct hole. It had some brackets on it, but i coudnt figure out how it mounted. I know from random pictures that it is mounted next to the windshield washer fluid reservoir, but i need an actual pic of how it mounts. Can someone help me out with a pic?
Thanks
'86 2wd now...
Ferg
It mounts high on the drivers side fender apron.  Two bolts in the vertical and one bolt on the angled portion of the apron.
kyle_22r
mounts on the side of the fender right next to the voltage regulator
YOguyDa
I'll mess with it some more, but a pick would help the most...Because its quite possible the wrong brackets are on it?
'86 2wd now...
notajeep
My truck didn't come with ps. When I upgraded only one hole was on the fender for the reservoir.....So I drilled 2 more using the bracket as a guide..  I dosen't sit perfectly level...but it's close.  I think that it originally came off an 83. mine is a 1980.
