New Heavy Duty Tacoma E-Locker Guard (2016-23 8.75" rear axle)
Started by Marlin Crawler, November 26, 2025, 04:09:35 PM
Marlin Crawler
Fits 2016–2023 Tacoma with rear 8.75″ E-Locker
We're excited to announce one of our cleanest, strongest new products of 2025:
Our Heavy Duty Electric Locker Guard, engineered to replace Toyota's thin cover that leaves the locker sensors, plugs, and wiring exposed to trail damage.
Features
  • Heavy Duty Plate steel replaces thin sheet metal
  • Full lower-face protection
  • Eight-bend formed single-piece construction
  • 100% bolt-on
  • Zinc plated
  • Protects components that require diff disassembly if damaged
Overview
  • OEM thin cover leaves the indicator sensor exposed
  • Our guard replaces it with zinc-plated 3/16" steel
  • Protects actuator, lock sensor, plugs, and wiring
  • Deflects upward impacts that Toyota's design leaves vulnerable
  • Direct bolt-on using factory bolt holes
  • Installs in minutes
  • Designed, cut, formed, welded, and coated in the USA
Click here for more details!
Install Video
Pictures (more on our website)
Spring Trail Season Is Here - Quick Pre-Season Check + 10% Off
Private Messages are not monitored
Please contact us at MarlinCrawler.com/contact or (559) 25-CRAWL / 559-252-7295
