2.28 replacement gears??
Started by Paulfreer, November 06, 2025, 09:13:50 PM
Paulfreer
Ok, so I had a idler gear in the transfer case chunk out and also chip the front output gear.
I have a dual case btw
I've purchased 23 spline input gears (2) from marlin. I'd like to replace the main gear, counter gears with new, but can't locate any.
Is the only option junkyard gears or the trail gear 2.28 set?
Btw, the trail gear 2.28 set don't seem to be sumo gears, so im a little hesitant to go that route.
Thanks for any help
I also need to replace the idler gear and output gear, but im guessing the only option is junkyard parts.
