03 Sequoia will not turn over
Started by rmoore, May 07, 2025, 04:44:46 AM
rmoore
Bought a new to me 03 Sequoia the other day, in limp mode due to a p2118 code. It was a blown fuse having to do with the drive by wire (dbw) bs. Caused by shorting the battery or crossing terminals when jump starting. Easy fix and and everything was running smooth. Drove it and parked it and 2 hours later it wont turn over. Everything else works but will not engage the starter one bit. All fuses and relays seem to be good, bat cables and connections good. BUT... I cannot find the starter relay?? Anyways, any help would be great. Thanks fellas. Also, is this posted in the right spot, cause i didnt see a Sequoia specific forum.
rmoore
Update.. It started just fine this morning. I checked fuses and relays but cannot find the starter relay. Any ideas, its not inany of the fender boxes.
Toyotadon
